Author Topic: MS Pac on start up. (all is working :) )  (Read 7603 times)
daywane
  • GRRRR!
« on: April 05, 2005, 09:55:44 am »
I am setting up a MS PAC cab. Wife is being kinda anal about this one.  ::)
If I could just figure out how to make it boot right to Ms PAC . I would be so happy.
all she wants is Ms PAC
I allmost tossed in a console but we want a vertical screen
I have never used Mame for dos. Never used dos before eather.
can I tell Mame to load MS PAC on start up?
can I tell Mame 32 to load Ms PAC on start up?
I do not care if the GUI shows up at first and then boots up MS PAC.
« Last Edit: February 13, 2006, 09:05:21 pm by daywane »
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: MS Pac on start up.
« Reply #1 on: April 05, 2005, 10:03:07 am »
If it is to play only ms pac man. The dos is the simpliest i think.
Install dos on your machine
Install your Dmame
youki
    • Atomic Front End
« Reply #2 on: April 05, 2005, 10:08:16 am »
On window, you can say MAME32  or MAME to start on Pacman too.
There is lot of solution , one can be to do .BAT too.
I suppose your mame is in  C:\mame   and the .Exe is called mame32.exe
Open the nodepad.
Type :
C:
cd \
cd mame
mame32.exe roms\pacman.zip  -skip_disclaimer -skip_gameinfo
Save the file and give the name :  Pacman.bat (for instance)
With windows explorer, select the file , right click, select copy.
Then right click on the "start" menu of windows. Select "Explore"  , find the folder called "Start up".
Right click,  select "Paste".
Now when you boot, you will be directly on Pacman.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #3 on: April 05, 2005, 10:50:21 am »
You should consider using Vantage instead of Mame. You could fit Vantage and the mspacman rom on a bootable floppy disk; so you wouldn't even need a hard drive. The only tricky part would be setting up your sound card. If you want to try it out, I can email you a bootable floppy image (without the rom of course) that's set up to run Vantage immediatley on boot up; just let me know what kind of soundcard you'll be using.
daywane
  • GRRRR!
« Reply #4 on: April 05, 2005, 08:34:42 pm »
Thanks guys.
Give me a few days to get the old crapy PC going and will give it a go.
JLR2000
  • Last login:December 28, 2025, 10:50:05 pm
  • There is NO Sanctuary...
    • WWW
« Reply #5 on: April 08, 2005, 08:39:01 pm »
Thanks guys.
FYI, I found this site very valuable when setting up my dos base Pole Position cab (boot directly to Pole Position):
http://www.mameworld.net/dosmame/
Lots of info no matter if you know DOS or not.....Good Luck.
daywane
  • GRRRR!
« Reply #6 on: February 12, 2006, 06:08:38 pm »
I suppose your Mame is in  C:\mame   and the .Exe is called mame32.exe
Open the nodepad.
Type :
C:
cd \
cd mame
OK I did as above
I had to remove the "-skip_disclaimer -skip_gameinfo" part
I guess mame 56 can not do this
works if I have this in a .bat file in start up folder
C:
cd \
cd mame
only problem I have is
my monitor is on its left side.
pivot pro rotated to 270 deg.
Mame starts up fine , but the ROM will not rotate.
If I start Mame with out the .bat file , Mame 32 is rotated and I have the display properties rotated clockwise
every thing works fine
I do not mind the hit any button part. I really would like to have the .bat file to work with a rotate. Like I said above, I can live with the hit any button to start game.
i like how I can hit escape and the game menu is there, but Ms PAC starts up 1st thing for my wife
« Last Edit: February 12, 2006, 07:24:38 pm by daywane »
youki
    • Atomic Front End
Re: MS Pac on start up. (rotate problem)
« Reply #7 on: February 13, 2006, 04:31:51 am »
HI,
I don't really know mame 0.56.
But may be you can try to put :
mame32.exe roms\pacman.zip -ror    (or -rol)
or
mame32.exe roms\pacman.zip -autoror    (or -autorol)
Or let your .bat as it is. create a INI directory , an a pacman.ini file with :
ror 1
(or rol , autoror, autorol)
daywane
  • GRRRR!
« Reply #8 on: February 13, 2006, 06:21:30 am »
HI,
or
ror 1
I will try
or
after work
Yawn only 3 hrs sleep  :-\
if i end up doing a ini
do I just make a folder called ini?
put a text in it with note pad
ror 1
do i save it as mspac.ini ?
never worked with ini files (one of the reasons I never fooled that much with command line type mame
youki
    • Atomic Front End
« Reply #9 on: February 13, 2006, 06:31:42 am »
Yes, just create a ini folder under the place where is your mame.exe
create the file called <romname>.ini  ,  if your rom is pacman.zip, the ini file must be pacman.ini
If your rom is mspacman.zip , the ini file must be mspacman.ini
And in the ini file just type with the notepad  :
Code: [Select]
ror 1
save and quit.
(be sure that the ini file is a .ini  , and not a  .ini.txt  (sometimes notepad can add the .txt))
daywane
  • GRRRR!
« Reply #10 on: February 13, 2006, 06:01:52 pm »
well... adding -ror to my bat file worked!
but ( notice how there seems to always be a but :-\ )
I have no joystick support on Mspacman.
I bet I need to add joystick to my bat file
so I am turning mame32 into a command line type mame for this 1 game?
then if I hit escape , Mame 32 takes over?
daywane
  • GRRRR!
« Reply #11 on: February 13, 2006, 08:20:39 pm »
Problem solved ;D Thank Youki ever so much
made a batch file
C:
cd \
cd mame
mame32.exe roms\mspacman.zip -ror -joystick
put in startup folder
I have joy to mouse in startup
mame.exe shortcut in startup
on boot up pivot pro flips my screen ( I only have this for exiting windows)
any one know how I can get windows to shut down with a Microsoft sidewinder button?
joy to mouse lets me use my joystick as a mouse ( only needed to pick games in mame 56. ) ( mame 56 will not use game pick with joystick that I know of)
bat file takes over as mouse to joystick is setting up
ms pack finally starts.
works perfect
If I did not have the shortcut to mame .exe in start up , I would hit escape and be back to desktop
now with mame in start up after I hit escape ,I get Mame32's menu
I am going with gamepad hack because this PC is a real piece of crap
USB port will not work
PS2 keyboard port has the black plastic piece to the keyboard broke inside it.
I have the keyboard the broke off still plugged in . so I am stuck with this keyboard only
sidewinder hack seemed the best option for this PC
