Author Topic: Advance Menu assistance needed  (Read 2038 times)
thelevin8r
  • Last login:June 09, 2006, 03:25:20 am
« on: November 17, 2002, 06:02:37 pm »
I am currently using ArcadeOS and AdvMame on an arcade monitor. I am trying to give Advance Menu a try, and I am starting to get a head ache! When I look in the advmenu.txt file so I can get the video set up right, it says that "All the `device_video_*' options defined in the advv.txt' file can be used." Well, when I look in there I can't make any sence of it. What changes to I need to make in the advmenu.rc file so that I can see the display? whatever it is running at now my arcade monitor can not display.
Is there a forum dedicated to advmenu? I'm sure I could learn all I need to know there.
jimlab
  • Last login:July 02, 2003, 05:05:10 pm
  • I'm not a llama.
Re:Advance Menu assistance needed
« Reply #1 on: November 19, 2002, 05:07:06 am »
You need to run advcfg.exe first and enter the basic settings for your particular monitor type. Then you use the advv.exe utility to 'fine tune' the individual resolutions and create custom resolutions if the ones you need don't already exist.
Read advcfg.txt (pretty straight forward) first, and then advv.txt. Here's a great resource for guiding you through the process of configuring your video mode(s) and resolution(s) properly...
http://easymamecab.mameworld.net/html/advcfg.htm
thelevin8r
« Reply #2 on: November 19, 2002, 09:36:56 am »
I didn't think that was necessary because I have already gone through those steps when I set up ArcadeOS/AdvMAME, but I will so again. I did notice when I was unzipping AdvMAME that it had newer (and larger) versions of these files. Thanks again for the help!
jimlab
  • I'm not a llama.
« Reply #3 on: November 20, 2002, 12:06:50 am »
If you have already run advcfg.exe, then you're fine, but you should run advv.exe with the -advmenuv parameter (read the file advv.txt in the advmenu .zip file for instructions) to set up resolutions for advmenu.
Your section option is to cut and paste your resolutions from advmame.rc into advmenu.rc so that it can use the same resolutions.
The following is an example only, and should not necessarily be pasted into your advmenu.rc file. Your monitor settings may be different and you should use the values you find in your own advmame.rc file, assuming that you have it configured correctly...
device_video_format 15750 0.645161 0.16129 0.0645161 0.129032 0.916031 0.0114504 0.0114504 0.0610687
device_video_pclock 5-80
device_video_hclock 15.75
device_video_vclock 50-60
device_video_modeline standard_384x288 9.68352 384 496 536 616 288 299 303 317 -hsync -vsync
device_video_modeline Custom_240x248x8 6.92999 240 336 360 440 248 251 254 271 -hsync -vsync
device_video_modeline Custom_256x242x8 6.93 256 344 376 440 242 244 247 261 -hsync -vsync
device_video_modeline standard_vga_328x240 8.30015 328 424 464 528 240 243 246 262 -hsync -vsync
device_video_modeline ntsc_320x240 8.05581 320 416 440 512 240 244 247 260 -hsync -vsync
etc.
Copy and past the device_video_format line, device_video_pclock, etc. and then any device_video_modeline values that you want to be able to use in AdvMenu. You only really need one modeline, once you find the one that works best for you and looks the best on your monitor.
To switch between resolutions, change the parameter of the following line in advmenu.rc. You only need the "X" value, AdvMenu will take care of the rest.
video_size 512
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
« Reply #4 on: November 20, 2002, 01:32:26 pm »
Advmenu and Advmame can be a ---smurfette--- startin up.  Here is what I did to get it goin.
c:
cd mame
del *.rc
advmame -default
advmenu -default
advcfg -advmamec
advv -advmamev
(* if your screen is scrolling or you cant see it, you have to redo the advcfg again, something if not setup correctly*)
(*test your games for advmame)
advmame pacman
advmame mslug
advmame nbajam
(* If the games work then config advmenu, if not try again *)
advcfg -advmenuc
advv -advmenuv
advmenu
(* test advmenu *)
