Author Topic: Mounting my I-Pac  (Read 2142 times)
BorgWarner
  • Last login:April 10, 2005, 10:42:44 am
Mounting my I-Pac
« on: April 05, 2005, 12:25:50 am »
I'm getting ready to mount my I-Pac inside my control panel but I'm kinda afraid to just screw it in there...any advise?  Thanks...
pointdablame
Re: Mounting my I-Pac
« Reply #1 on: April 05, 2005, 12:30:48 am »
you could use some PCB mounting feet.
Or cut up the shaft of a bic pen and put a screw throught the Ipac and then the pen so it's raised slightly
first off your and idiot
ginno
  • Last login:April 22, 2008, 07:46:56 am
  • Gindustries Arcade
« Reply #2 on: April 05, 2005, 02:41:39 am »
I used those little hexagonal brass screws that sit between motherboards and the metal casing of my PC.
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« Reply #3 on: April 05, 2005, 03:43:48 am »
Buy a set of these PCB standoffs from a electronics store.
I love the life I lead. I wish I could afford it.
Franco
« Reply #4 on: April 05, 2005, 04:07:13 am »
I used the $3 PCB mounting feet that I bought from ultimarc at the same time that I bought my I-Pac.
paigeoliver
  • Awesome face!
« Reply #5 on: April 05, 2005, 04:14:59 am »
I usually use duct tape, bondo, superglue, or cabbage!
Actually I usually use PCB feet if I can find any, but I have also just screwed them down in the past with no ill effects.
I actually had one hanging loose in a cabinet for a year and a half with no problems. That was back before I was hyperactive on these forums, my wiring got a whole lot better after I started seeing everyone ELSE's ultraclean wiring jobs.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #6 on: April 05, 2005, 08:33:08 am »
I will throw in a second for the brass hex computer standoffs. Just mark holes, drill so the hole is undersize, screw the standoff into the wood with a nut driver, and mount your PCB like a motherboard. Works great!  Besides, what self-respecting geek doesn't have at least 1 metric ton of those things laying around ???
Craig
« Reply #7 on: April 05, 2005, 08:44:19 am »
I could only see the thing staying in for a short time. I'd add very strong glue for the screw standoffs to make sure they never dislodge from the timber.
nostrebor
  • SHOCKING!!
« Reply #8 on: April 05, 2005, 11:21:29 am »
I used a bunch of them for my MAME cabinet... you would have to literally hammer on them to dislodge them. You want the drilled hole a tight interferrence fit, so the standoffs cut full threads into the wood.
Just thought of this: Mine are screwed into plywood. I would not recommend this procedure in MDF without using CA glue also. (Crazy glue) Definitely test a few before commiting your PCBs to them.
Goz
  • KOTA
« Reply #9 on: April 05, 2005, 12:19:39 pm »
If you want actual PCB mounting feet. Ponyboy has them cheap!
-Goz
Sinner
  • Last login:September 17, 2024, 11:27:45 am
  • Half the lies they tell about me, aren't true...
    • Geek My Gadget
« Reply #10 on: April 05, 2005, 12:29:46 pm »
I wanted spacers to hold my mobo off the inside of my cab, so I went to Home Depot and picked up some nylon nuts (they're an easy way to make sure the spacing is the same and for $0.29 each I don't have to bother cutting anything to size)...
Basically, anything that doesn't conduct electricity very well should work (IE: rubber tubing, plastic tubing, etc)...
Mark the holes, predrill and run the screws through your board and the spacer of your choice...
Paul Olson
    • Paul's Arcade
« Reply #11 on: April 05, 2005, 02:17:41 pm »
I used the motherboard standoffs, too, and they have worked great.  How is everyone mounting the AKI Boards?  No mounting holes on these.
Paul
koolmoecraig
    • My Intervention
« Reply #12 on: April 05, 2005, 02:32:35 pm »
Velcro dude. Velcro.
Leaves no marks, it's pretty much impossible to screw up, and you can remove it instantly.
What's the point of nylon nuts, washers, marking holes, drilling holes etc?
Oh yeah, it costs about 50 cents.
« Last Edit: April 05, 2005, 02:34:42 pm by koolmoecraig »
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #13 on: April 05, 2005, 03:24:34 pm »
Doesnt velcro cause static electricity?  Either way, Im cheap so Im gonna use a cheap pen.  You throw them out every day because they dont work....why not put it to good use!
Hoagie_one
  • Um....whats a cabinet
« Reply #14 on: April 05, 2005, 03:36:39 pm »
I've used teh bic pen in the past....getting good cuts is another issue though
JDSkydiver
  • Last login:March 09, 2006, 06:28:35 pm
  • Go Irish!
« Reply #15 on: April 05, 2005, 03:49:42 pm »
Yep...
I too have heard you can steal a cheap bic pen or two, cut them up into 1/2" posts and use them as mounting.
I mean PURCHASE a brand new Bic Pen...
JD
pointdablame
« Reply #16 on: April 05, 2005, 03:58:25 pm »
I definitely wouldn't use velcro.. that could cause static electricity and that's just asking for trouble.
I've used the brass hex shaped standoffs in my bartop, and actually, if you make the hole slightly smaller than the standoff, MDF will hold it fine.  Once I got them in, I was considering some glue, but those damn things would NOT budge.  Glue wouldn't hurt, but if you do it right, it won't be necessary... even with MDF.  I mean, its not like the Ipac is going to be dancing around in there.
