Author Topic: Golden Tee, Centipede, Happ, Wico Trackballs  (Read 2918 times)
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« on: April 04, 2005, 02:51:46 pm »
I've seen a lot of different trackballs for sale
Golden Tee trackballs ..
Centipede trackballs ..
Happ trackballs ..
Wico trackballs ..
etc. ..
Would any of these be just as good as the others for a MAME machine?
Are there any differences other than manufacturers?
Where can I get bearings and rollers?
Flinkly
Re: Golden Tee, Centipede, Happ, Wico Trackballs
« Reply #1 on: April 04, 2005, 03:17:23 pm »
if you wait another week or so, kevin steele will have finished his trackball roundup and reviewed them all for you.  as for golden tee and centipede, i think they are just the same as the manufacturers balls.  but i could be wrong.  and as for who's balls they are, i don't know either.
IntruderAlert
    • Intruder Alert
« Reply #2 on: April 04, 2005, 03:29:52 pm »
the golden tees look like they sit a little taller or something
Flinkly
« Reply #3 on: April 04, 2005, 08:27:07 pm »
oh, i forgot about that...those are happs high lip trackballs.  they are the same, but they have a stinkin lip on em.  i don't think you get any extra lift.
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #4 on: April 04, 2005, 10:19:11 pm »
The high lips are meant to be mounted under plexi.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #5 on: April 05, 2005, 12:45:37 am »
The Happ high-lip ball typically sells much cheaper than their standard or high ball versions, even though it's mechanically equivalent.  If you don't want the lip, just sand/file/dremel it off- it's just some soft black plastic, after all.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: April 05, 2005, 04:14:29 pm »
All arcade trackballs have lips.  All high lip models (betson and wico have their versions too) just lowered the top of the case body without moving the top of the lip compaired to the "original" arcade standard. (see below).
Happs case tops: High Lip vs normal lip
(You can make a normal happs TB a high lip model by just replacing the top of the case, shown above.)
edit: fixed missing word.
« Last Edit: April 06, 2005, 06:50:43 pm by u_rebelscum »
Robin
Knowledge is Power
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: April 06, 2005, 04:57:31 pm »
You can make a normal happs TB a high lip model by just the top of the case, shown above
"by just" what?
NO MORE!!
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« Reply #8 on: April 06, 2005, 05:29:46 pm »
Hmm... Is there by any chance an inexpensive way to hack a trackball to a mouse? I was looking at Ultimarc, and dang, that Optipac interface is expensive! I don't think I can spend $100 on a trackball. Is there a less expensive alternative?
Flinkly
« Reply #9 on: April 06, 2005, 05:56:45 pm »
um...mouse hack for 9 dollars by...dang, i forgot the name.
« Last Edit: April 06, 2005, 06:01:39 pm by Flinkly »
markrvp
  • NFL Expert
« Reply #10 on: April 06, 2005, 06:26:19 pm »
Do a search for Mouse Hack and you will find detailed instructions on this board.  There are also detailed instructions in the PROJECT ARCADE book.  If you haven't gotten this book already, I would recommend getting and reading the book before you get to far in your project.  It will give you all the info you need and answer a lot of questions even before you think of them.
I have an OSCAR controls mouse hack interface and it works very well.  You can also buy a HAPP trackball that is already PS2/USB compatible without using an additional interface like Mouse Hack or Optipac.  Go to the BUY/SELL/TRADE forum on this site and look for a thread by PONYBOY.  He sells these and you can see the prices there.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #11 on: April 06, 2005, 06:49:51 pm »
"by just" what?
Sorry, "by just replacing"  :-[
Robin
Knowledge is Power
JODY
« Reply #12 on: April 06, 2005, 07:35:17 pm »
I just took a good look at my new 3" translucent Happ trackball because I bought a used 2 1/4" without wires and used the wires off the 3" to test.
Anyway, noticed that my 3" is a high lip.
Timstuff
  • I feel asleep !!
« Reply #13 on: April 06, 2005, 08:44:55 pm »
Ultimarc has a trackball for $36, but I don't think that it comes with any sort of interface to connect it with your PC. Basically, I want to know where I can buy something inexpensive ($10-$20) so that I can connect it to my PC like a mouse.
http://www.ultimarc.com/JShopServer/product.php?xProd=24&xSec=2
Timstuff
  • I feel asleep !!
« Reply #14 on: April 06, 2005, 10:26:37 pm »
After searching this forum, I found an excellent how to for hacking a mouse for a trackball interface.
http://www.willcoxonline.com/mame/controlpanel/controlpanel.htm
I probably have a spare mouse or two laying around my house somewhere, so if I go with the Ultimarc trackball I could make my control interface have a trackball for only $36. ;D
