Author Topic: PC Problem  (Read 2846 times)
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
PC Problem
« on: April 04, 2005, 02:49:42 pm »
I'm trying to get an old motherboard working to make a MAME bartop or jukebox.  When I power it up, I get nothing on the monitor.
The PS starts, the HD spins, nothing else.
I tried a video card instead of onboard video, but still nothing.
Am I wrong to think that the first thing the MB does is start the video?
Art
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
Re: PC Problem
« Reply #1 on: April 04, 2005, 02:52:52 pm »
Do you have memory installed?
JackTucky
Re: PC Problem
« Reply #2 on: April 04, 2005, 02:57:45 pm »
Yes, one stick of memory.   I'm going to leave it "running" to see if the CPU gets hot.
Art
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
Re: PC Problem
« Reply #3 on: April 04, 2005, 02:58:50 pm »
How are you mounting the Mobo?  Place a sheet of cardboard under the motherboard to make sure it is not grounding out.
-d
Nothing witty here...move along.
JackTucky
Re: PC Problem
« Reply #4 on: April 04, 2005, 03:01:59 pm »
No mount yet   ;D   It's just sitting on my desk.  Put some cardboard under there though.  Thanks
IntruderAlert
    • Intruder Alert
Re: PC Problem
« Reply #5 on: April 04, 2005, 03:28:07 pm »
make sure that the memory is compatible with your mobo
also, some mobos require memory in pairs
if you google it a bit you might find a manual for it
JackTucky
Re: PC Problem
« Reply #6 on: April 04, 2005, 03:37:41 pm »
It's a Camaro motherboard.  I guess I need an oil change or something.
ARt
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
Re: PC Problem
« Reply #7 on: April 04, 2005, 03:49:23 pm »
About 2 years ago I owned an '89 IROC-Z (Z-28)..........you had to slam your fist in the dead center of the hood to get it to pop open....
Just a thought..... ;) ;D
Signature tags are dumb.
LordKaosNY
  • Last login:February 08, 2019, 02:55:52 am
Re: PC Problem
« Reply #8 on: April 04, 2005, 03:52:59 pm »
Does the MOBO have a built in speaker or speaker attached?  If so, it should be giving some indications of what the problem is such as short beeps for a video problem and long beeps for memory issues.
CPickler
  • Last login:August 20, 2006, 02:37:14 am
    • CPU Studios
Re: PC Problem
« Reply #9 on: April 04, 2005, 07:48:14 pm »
Almost all motherboards have built in speakers or an LED display.  This will show you POST errors.  It sounds like the motherboard may be bad.
Try powering on the motherboard with nothing plugged into it.  It should beep at you like crazy.  If it doesn't then your mobo is probably bad.
I can help you through this problem if you want, computers are definately my cup of tea.
JackTucky
Re: PC Problem
« Reply #10 on: April 04, 2005, 10:06:29 pm »
I have to find an extra PC speaker.  I tossed out this MOBO's with the case.
There is no LED.  Thanks
ginno
  • Last login:April 22, 2008, 07:46:56 am
  • Gindustries Arcade
Re: PC Problem
« Reply #11 on: April 04, 2005, 10:53:31 pm »
I had the following problem on the weekend
Computer worked fine,
put it in mame cab
Computer shat itself
Pulled the whole thing apart, vaccumed it all tried it with ram, without ram etc... nothing
About to give up, pulled off custom rewiring i did to put the reset and power buttons on the front of the cabinet
This worked
Looks to be almost like the reset switch was staying on, not allowing the compuer to boot up
I had many similar problems, HD worked, CPU fired up, nothing on screen
Not sure if this helps
Cheers ginno..
CPickler
    • CPU Studios
Re: PC Problem
« Reply #12 on: April 04, 2005, 11:58:07 pm »
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re: PC Problem
« Reply #13 on: April 05, 2005, 12:03:22 am »
Speakers arn't built into the motherboard that ive seen in a long time...yea, hook up a PC speaker to it, and what year was the mobo made? that will help with if you need 1 or 2 sticks of ram
CPickler
    • CPU Studios
Re: PC Problem
« Reply #14 on: April 05, 2005, 12:05:49 am »
there is usually a speaker that will beep and beep only.  At least motherboards made through 2004 usually have that capability.  It is not a full speaker.
The needing matched pair Ram also has not been an issue since 1995.
SirPeale
  • Green Mountain Man
Re: PC Problem
« Reply #15 on: April 05, 2005, 12:21:02 am »
Some boards do, some don't.  The one I just got doesn't, but the one I replaced did.
CPickler
    • CPU Studios
Re: PC Problem
« Reply #16 on: April 05, 2005, 12:24:07 am »
The majority that I have used myself or encountered (I work as a computer and network technician) have had either the speakers or some way of independently notifiying of problems, through beeps, leds, or even some with displays.
paigeoliver
  • Awesome face!
Re: PC Problem
« Reply #17 on: April 05, 2005, 12:44:36 am »
Check your PMs Jack, I'll just send you a whole working system. I have one gathering dust that used to power my Defender before I got a Multi-Williams board.
JackTucky
Re: PC Problem
« Reply #18 on: April 05, 2005, 10:20:00 am »
Replied paige.  Thanks
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
Re: PC Problem
« Reply #19 on: April 05, 2005, 10:49:20 am »
Sounds like a bad CPU to me.
