Author Topic: Video garbled in DOSCab Jukebox program  (Read 5338 times)
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
« on: November 15, 2002, 11:25:51 pm »
I just tried to run DOSCab Jukebox program and am having trouble getting the video to display properly.
I'm currently running "pure" DOS and using a Wells Gardner SVGA Monitor (1024x768 interlaced) and according to the DOSCab documentation, it should run under this video mode.
There is an entry for REFRESH RATE in the jukebox.ini file, but that doesn't seem to do anything?
Am i doing something wrong, or is the U3100 not a compatible monitor.
Chris
    • Chris's MAME Cabinet
Re:Video garbled in DOSCab Jukebox program
« Reply #1 on: November 16, 2002, 02:37:18 pm »
The refresh raes you're trying are probably too high for that monitor.
Try setting the following to the [Settings] section of JUKEBOX.INI:
RefreshRate = 0
This will keep DOSCab Jukebox from trying to set a refresh rate.  Right now it's trying to force the rate to 72hz which fails with your monitor.
--Chris
--Chris
liche
« Reply #2 on: November 16, 2002, 08:15:10 pm »
Thanks.  I'll give it a shot.  I did try changing that setting to 60 Hz, but didn't do anything.
Chris
« Reply #3 on: November 16, 2002, 11:53:33 pm »
60 Hz is too high for an interlaced mode.
--Chris
liche
« Reply #4 on: November 17, 2002, 07:30:47 pm »
Tried setting refresh rate to zero, but still didn't help.  Probably my video card.  Anyways, I'm getting a Trident T64 Blade video card this week, so that should hopefully work.
