Author Topic: Molex for swapping between IPac & DC?  (Read 1835 times)
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
« on: April 01, 2005, 08:31:22 pm »
When my cabinet gets here next week and I start working on the
control panel, I plan to make the P1 & P2 controls swappable
with my Dreamcast.
I think I want to go the route of Molex to plug/unplug the sets
of controls.
What do I need to know about these things?
Is there a certain size thats easier to work with than others?
Do I need tools to get the wires inserted into these things?
What size wire should I work with for the control panel  - that would
fit the molex plugs well?
thanks guys!  Cant wait to get the new cabinet and gets some
construction pics posted!
...so I will ask you... "Deal, or No Deal?"
kcoleman
  • Last login:September 18, 2005, 01:29:01 pm
  • My Mame obsession is driving my wife crazy
    • My Cab Blog
Re: Molex for swapping between IPac & DC?
« Reply #1 on: April 02, 2005, 09:23:18 am »
I am not an expert, but I beleive the cycle times for molex connectors are not that great.  They are made for something like 25 or so insertion/removal cycles.  Not sure if that will cause an issue. I might look at a D-sub connector.
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #2 on: April 02, 2005, 10:01:35 am »
Well if you actually look at molex connectors, youll realize that they arent that sturdy to hold up to changing them alot of times.  I would have to recomment a fingerboard.  Each panel gets its own fingerboard (1-3 bucks each) and then you need one connector in your cabinet (I hear these are a little more pricey).  Then, you just pull out the connector and insert a new one.  If you do it fancy enough, you can probably route a tunnel in your panel, put your wires in there, and cover it with a wood filler so nobody sees your wires.  Then on the far end, you route a space for your connector to slide into......I just got an idea!  Nobody will see my wiring!
daveg2000
    • www.davegrams.com
« Reply #3 on: April 03, 2005, 10:36:41 pm »
Hmmm.. bummer.. thats not good news.. I was looking forward to doing this.... (sounded easy and mostly solder free - except for a bit on the Dreamcast controller)
Fingerboards look like it might be a little tough.
I saw a post on using diodes also between the DC controller
and the IPac.. but I guess I dont want to have 20 diodes to
solder and have hanging around under the cabinet either...
do I?
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #4 on: April 03, 2005, 11:56:23 pm »
I used crimp style D-Subs for my control swapping, works great.
daveg2000
    • www.davegrams.com
« Reply #5 on: April 04, 2005, 07:59:24 am »
Any pics by chance?
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #6 on: April 04, 2005, 10:38:50 am »
I'm surprised that molex connectors have such a low cycle number...I would've figured them to be a lot more robust than that.  Huh.
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #7 on: April 04, 2005, 11:55:40 am »
I also use D-Sub connectors.  You can get a 50-pin male and female for under 10 bucks which should be more than enough.  You could probably use a standard dB25 connector if you are only using P1 and P2.  I used a 50 pin because I have all 4 player controls plus trackball and spinner.  I was able to get them all on a SCSI connector.  I have swapped it out at least 100 times and everything is still tight and workign great.
ED7
