February 23, 2026, 03:41:18 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Main
Main Forum
YDKJ, Drilling Pushbuttons
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: YDKJ, Drilling Pushbuttons (Read 1601 times)
SteveJ34
Trade Count:
+9
Full Member
Offline
Last login:January 06, 2024, 12:29:40 am
on:
March 31, 2005, 08:19:35 pm »
I've finally got all my parts in for this project. I went with the shallow happ buttons suggested by Sasquatch based on the depth of the box.
I'm planning to make the hand buzzers using chopper bicycle grips, the same shallow pushbuttons (they fit nice and snug) and a piece of 1/2" PVC inserted down in the handle to firm up the inside.
My question is.....
What should I use to drill the holes in what appears to be like 1/16" aluminum plate on the control box for the pushbuttons?
Historically I have done all my panels and button mounting projects in wood so other than small holes I have drilled in metal and aluminum strips for trim/framing in some marquee sign projects, I'm not completely sure what would be best for this so I don't screw the panel or the bits I have onhand.
These shallow pushbuttons are stated as being .93" diameter which is a bit larger than 7/8" so I guess I will have to go with 1" bit.
I look forward to any and all replies.
Steve
Logged
hiperco
Trade Count:
0
Full Member
Offline
Last login:January 14, 2014, 08:15:13 pm
Mame is Cool
Re: YDKJ, Drilling Pushbuttons
Reply #1 on:
March 31, 2005, 08:44:38 pm »
How about a chassis punch? (Not cheap though).
If it is aluminum, a hole saw, lubrication, and lots of elbow grease might work.
Try googling "chassis punch", lots of info there.
Logged
kcoleman
Trade Count:
0
Full Member
Offline
Last login:September 18, 2005, 01:29:01 pm
My Mame obsession is driving my wife crazy
Reply #2 on:
March 31, 2005, 10:30:28 pm »
I think you can get bimetal hole saws that should be able to drill through the aluminum. It would be easier if you have a drill press but if not you will have to use a variable speed drill, tightly clamp the piece and go slow.
Logged
http://megarcade.blogspot.com
Trimoor
Trade Count:
0
Full Member
Offline
Last login:November 18, 2006, 09:01:46 pm
I like shooting out of helicopters.
Reply #3 on:
April 01, 2005, 12:06:34 am »
I used a hole saw in 1/16" aluminum with no lubricant and had no problems. Make sure you use a decent saw though.
Logged
Need electronics help? Ask me. I just might give an answer.
Contact Me.
Build Your Own Rotary Joystick!
SteveJ34
Trade Count:
+9
Full Member
Offline
Reply #4 on:
April 01, 2005, 08:15:46 am »
Thanks for the replies, gentlemen.
I was expecting that a hole saw would probably get the job done. The material is pretty thin so this shouldn't prove to be that difficult. Clamping the piece tightly so it doesn't take off on me when the hole saw starts to grab is a smart suggestion.
I appreciate the input and hopefully will have a pic or two to post after a little weekend activity.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
