Author Topic: Enable Panning AVGA  (Read 1709 times)
vader
  • Last login:January 19, 2025, 08:25:22 pm
  • I can't breathe in this thing !!
Enable Panning AVGA
« on: March 31, 2005, 04:48:25 pm »
I very rarely go to the desktop on my WinXP machine which has a AVGA card and CGA VisionPro monitor cause I usually do most from another remote computer, but on occasion is necessary.  I run my desktop resolution at 640x288, seems to be the  best picture quality for a CGA monitor.  I do however get some of the screen which I can't read, so if I need to make changes, I have to change to 640x480 for a few seconds to make the change and I'm sure this can't be good for the monitor.  Is it possible to enable panning from the video card driver so I can avoid doing this in the futre.  I was able to do this in the past on my Windows machine which had both a Nvidia card and ATI ( secondary display was a tv ) any help appreciated.
Tim
hiperco
  • Last login:January 14, 2014, 08:15:13 pm
  • Mame is Cool
Re: Enable Panning AVGA
« Reply #1 on: March 31, 2005, 11:54:34 pm »
I can't seem to get this working, but There's a link here:http://www.ultimarc.com/avgainst.html
You may need the "old" version of the ATI software (but again, I have bad luck with this).
Enable Auto-Panning in Windows XP and 2000.
Click Display, Properties, Advanced, Displays. Click on the active (top left) Monitor heading. In the "Max Resolution" drop-down, select "648 X 288". The desktop will now be a clear non-interlaced display, which auto-pans up and down. If you wish, click on the ATI taskbar icon and increase the desktop resolution to 800 X 600 or 1024 X 768. To turn off auto-pan, select 640 X 480 in the "Max Resolution" drop down box, as above.
