Author Topic: Windows on Arcade Monitors  (Read 7899 times)
Chazz
  • Last login:January 29, 2020, 01:14:53 pm
« on: May 06, 2002, 12:50:45 pm »
How can I run Windows on my arcade monitor?
Will it only work with certain monitors or video cards?
Do I need to use special drivers or settings in Windows?
~ChaZz
Lilwolf
Re: Windows on Arcade Monitors
« Reply #1 on: May 06, 2002, 03:15:46 pm »
Not well.
the best I've heard about is
JPac (so if you have the wrong settings, you wont blow your monitor)
m400 (Malox card)...
special drivers for the malox.
I've also heard of some very expensive scan converters working.  this is the BEST solution (the example I saw... who had that 52" sit down cab??).  The output was AMAZING... everything looked FSAA and great... but the converter was new at $2000 or so.  But you might be able to find some of the great scan converters on ebay for a few hundred.
If you only want windows for config... JPac can do it with some additional cards I believe... but it will double the screen (so you see it twice)...
wrybread
« Reply #2 on: May 10, 2002, 01:52:10 am »
FYI, i think he meant "matrox" on the vid card, not malox.
Mark
  • Last login:March 22, 2013, 09:11:11 am
    • Arcade Jukebox
« Reply #3 on: May 10, 2002, 09:02:26 am »
I am using a Matrox G400 card with the g400interlace.exe program.  Works great.  Once your in Windows you need to start the g400interlace program and turn on the arcade monitor.
Mark
Arcade Jukebox
Chazz
« Reply #4 on: May 10, 2002, 09:14:29 am »
Can I run Windows on a arcade monitor with this card:
ATI Xpert 98 Pro AGP Rage Pro Turbo
Mark
    • Arcade Jukebox
« Reply #5 on: May 10, 2002, 12:50:17 pm »
Check out
http://www.mameworld.net/suzuki2go/vsyncmame/
for info on cards that work.  The G400 seems to be the best for Windows.
Mark
Arcade Jukebox
