Author Topic: monitor testing on bench  (Read 1166 times)
mammoth
  • Last login:March 27, 2006, 12:36:26 pm
« on: March 22, 2005, 09:05:47 am »
 any idea on setting up a cheap and easy test bench for monitors- (mainly cga) - I have many misc. parts to build from i.e old boards. iso transformers, ect. also would like it to produce cross pattern to get convesence close.
MonitorGuru
Re: monitor testing on bench
« Reply #1 on: March 22, 2005, 09:29:41 am »
Find an old Commodore or Atari RGBA (analog RGB) 13" monitor from their Amiga/ST lines (e.g. 1902/2002/1080 on commodore and I forget the Atari model #'s) and then make an adaptor to go into the analog RGB port.
They sync at 15.75KHz and have built in isolation.  Quick, easy.
For crosshatch/color, pick up a really cheap JAMMA board off of eBay. Even one that doesn't work but ask the seller if it will work in test mode.  Run thru a few games in MAME and test out their test modes to see which ones produce the best monitor patterns for you.
mammoth
« Reply #2 on: March 22, 2005, 09:37:09 am »
hey- i'm old but even i don't have any more 13" games are you saying use something like an old missle command board or what-don't quite understand.
« Last Edit: March 22, 2005, 10:40:57 am by mammoth »
