Author Topic: Problems running ROMs with ARCADEOS  (Read 3403 times)
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
« on: November 11, 2002, 09:01:01 am »
First, my current set-up.  ArcadeOS running DMAME on pure DOS.
My problem is that I cannot get ArcadeOS to run roms that DMAME can run perfectly fine on my machine.  I checked the paths in the arcadeos.cfg file and everything seems okay, and ArcadeOS does find the romsets and lists them, but everytime i go to launch a game, it comes up with errors.
Am I missing something else?  Do I need to make Merged Romsets = YES???
Any help appreciated.
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Re:Problems running ROMs with ARCADEOS
« Reply #1 on: November 11, 2002, 12:58:07 pm »
What is the errors you get?
Can you run in dos something like:
dmame pacman
liche
« Reply #2 on: November 11, 2002, 01:33:58 pm »
Its come up with the standard errors typical when you run a romset that is corrupt or not valid - about 4-5 different error messages.
However, when running DMAME directly it works . . .
For example,
dmame mspacman -soundcard 1
or
dmame gyruss
My DOSMAME is loaded into directory C:\DOSMAME while AdvMAME is loaded into directory C:\MAME
The arcadeos.cfg file directs everything to c:\DOSMAME, but maybe there is something else it doesn't like about that directory.
Superdude
« Reply #3 on: November 11, 2002, 03:03:33 pm »
You just answered your question right there.  Arcadeos must have a directory called c:\mame with all your mame software and advance mame.  For some reason, (I expect hardcoding), Arcadeos cannot run mame without it being in this directory.  I had problems with this before and decided not to fight it anymore.  Make a Mame directory and copy everything there and reinstall Arcadeos.
liche
« Reply #4 on: November 11, 2002, 09:30:35 pm »
Thanks.  When I originally installed the Fraggal Boot CD, it installed ArcadeOs and AdvMame in C:\MAME.  I then installed regular DOS Mame into a directory called C:|DOSMAME and configured arcadeos.cfg file to run everything from there.  But i guess as you say, it doesn't like it.  I'll re-install everyting tomorrow and install Dos Mame into C:\MAME
Yeah, the errors I get are:
ROMS not found, etc.... even though they are there.
Thanks again
Superdude
« Reply #5 on: November 12, 2002, 10:56:56 am »
I notice that 61.4 of advmame also has a small bug in the cfg file.  Make sure it is pointing to ROMS and not ROM for the directory name.
