Author Topic: bad pacman monitor?  (Read 1285 times)
unix4hire
  • Last login:October 16, 2008, 06:12:47 pm
  • activate interlocks...
    • My Business
bad pacman monitor?
« on: March 17, 2005, 09:30:10 pm »
Hi, I finally got my pacman working by sending my board off to twobits for repair.  Now my excitement disappears after playing for about 10-20 minutes because the monitor/screen starts getting all intermittently jiggly and eventually turns into a solid vertical line in the center of the screen.  Is this what I fear it is?  A monitor going out?  Or something more benign?
menace
Re: bad pacman monitor?
« Reply #1 on: March 17, 2005, 09:34:42 pm »
sounds like a cold solder joint somewhere in the horizontal section --get a real bright light, a magnifying glass and have a look around--you're looking for anything that has separated from the board or a solder joint with a hairline crack in it.
MonitorGuru
« Reply #2 on: March 17, 2005, 10:37:49 pm »
Nope, it's a vertical deflection collapse... remember a Pacman monitor is rotated 90 degrees from a TV set.
Besides cold solder joints, your yoke wire may have simply come unplugged from the board or from the yoke. Check the Yellow and Green connectors.
More dire, would be a short in the vertical winding on the yoke or part of the vertical circuit is dead.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 18, 2005, 07:10:28 pm »
Sounds like you have a Wells-Gardner 4600 series monitor. Yes, it has numerous bad solder joints that cause the exact problem you have described.
