Author Topic: Trackball comparrison  (Read 1205 times)
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« on: March 17, 2005, 05:58:41 pm »
Sorry if this was posted before:
After looking for trackballs from Happs and Ultimarc, I see that Ultimarc tends to be cheaper, ALOT cheaper.  Since Im already orderring a ton of stuff from Ultimarc, I wanted to know what the differences were with the trackballs, besides the size.  Im going to order a minipac, which the trackball can connect directly to, so I figure.....what's the diff!
EDIT:  ANYBODY?
« Last Edit: March 17, 2005, 09:31:34 pm by cholin »
Flinkly
Re: Trackball comparrison
« Reply #1 on: March 17, 2005, 10:17:47 pm »
like has been said numerous times before, if you'll only use it every once in a while, the ultimarc is a fine canidate, but for heavy users, the industrial quality happs is the way to go.
« Last Edit: March 17, 2005, 10:26:10 pm by Flinkly »
cholin
    • Nilok Productions
« Reply #2 on: March 17, 2005, 10:21:51 pm »
Whoa, just as I'm typing my reply, I look down and the thread has been edited :)  That was surely cool.  Thanks though for the information.  I think Ill probably go with the Ultimarc one and maybe buy a replacement ball -- I guess I should search ebay first :)
GGKoul
  • Cheesecake Apprentice
« Reply #3 on: March 17, 2005, 10:47:37 pm »
Retroblast is doing a trackball review soon.  So I guess it'll be up in a few weeks.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: March 18, 2005, 06:52:19 am »
Just to point out the physical differences between our trackball and Happ:
Ours has a slightly heavier solid ball
The metal shafts on ours have plastic sleeves which act against the ball. The idea behind this is to avoid the metal to plastic contact of a bare shaft. The Happ has the same shafts, bearings, etc but does not have the plastic sleeves.
I think it's fair to say that the bearings on ours are initially sometimes rather sluggish and require bedding-in and maybe even some WD40, whereas the Happ seems to be free out of the box. I suspect they use bearings with a thinner lubricant.
Andy W
