Author Topic: "Come On Baby" Help me with this Weird Korean Machine - PLEASE!!!  (Read 9627 times)
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
I recently purchased this machine.
I'm not sure if I want to restore it or part it out or what.
It's a pretty strange Korean machine called "Come On Baby"
It's hard to tell but there is what appears to be some water damage on the bottom rear corner of this side
It's also sitting a bit tilted back
I think the rear wheels have collapsed under it or something.
As you can see it actually runs on a Windows 98 Celeron 500 PC
The monitor looks like a flat screen 29" or 27"
There is some discoloring in the bottom left and top right corners
Can this be fixed?
And it's all 220v so it has to be powered by the power converter on the left of the PC case
I believe this is some sort of transformer in the bottom right corner
It isn't even bolted down.
And I'm not sure what the thing in the top right corner is yet.
This appears to be an interface for the controls
And I believe this is an amp for the speakers
I have no idea how much of this stuff is OEM and how much has been added on.
At first this machine would not even come on.
There is a switch on the top of the cab and another near the bottom right when looking at the back of the cab.
Both of these switches seem pretty worn out.
After a few minutes of trying I was able to get the machine powered up and it played for a while before shutting itself off.
I was able to get it powered up once more but this time it booted all of the way into Windows and restarted itself about three times before blowing a fuse on the power converter.
I need to go over all of the wiring and see if there is a short somewhere I guess.
The power converter is a little noisy. I'd like to know if there is a way around using it.
I'd also like to know how to correct the discoloration on the monitor.
Some of the panels of the cabinet are too loose and need to be refastened.
If I'm not able to repair the machine I guess I'll end up parting it out.
and in that case:
I don't know if this sort of monitor would be good for a MAME system or not.
And if I ended up using the monitor in a MAME system, would it have to use a 220v power converter like this?
Also, I'm not sure what else I could do with the Celeron 500
Wouldn't MAME require something more powerful?
Any help or suggestions you guys can give me will be very much appreciated as always.  :)
CLICK FOR FULL SIZE
« Last Edit: March 17, 2005, 01:09:51 am by IntruderAlert »
redcoats
  • Last login:March 15, 2015, 04:04:56 pm
Re: "Come On Baby" Help me with this Weird Korean Machine - PLEASE!!!
« Reply #1 on: March 17, 2005, 01:45:27 am »
I think you can fix the monitor by degausing(sp?) it. Someone correct me if I'm wrong. I'm not sure what to tell you. It is very funky looking but it may be worth money if they didn't make very many.
IntruderAlert
    • Intruder Alert
« Reply #2 on: March 17, 2005, 01:50:59 am »
Thanks,
Does anyone recognise the monitor or have a suggestion on how to degauss?
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
« Reply #3 on: March 17, 2005, 01:56:08 am »
it looks like the monitor problem is from magnetizing...most like from the magnets on the speakers if they arent sheilded.
i had that problem once, i removed the speakers, and it fixed itself in a days time. i then put in the proper speakers.
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
IntruderAlert
    • Intruder Alert
« Reply #4 on: March 17, 2005, 01:59:50 am »
yeah.. but it's weird that its just in those two corners.
2600
« Reply #5 on: March 17, 2005, 08:39:24 am »
Here's a couple of notes.
1. Create a backup of that drive.  Maybe the MAME Dev's want it, maybe not, but you should create a backup of it.
2. The monitor probably just needs to be deguassed, this happens when you move monitors no big deal.  Post a question in the monitor forum and they will set you straight.
3. The powering chain is probably the problem, but it's hard for me to see where everything is going.  You've got a power converter(what's it rated for), possibly a transformer, etc.
IntruderAlert
    • Intruder Alert
« Reply #6 on: March 17, 2005, 09:50:41 am »
Hopefully I'll get a chance to go over the wiring tonight.
If I can get it going again I'll post some pics.
I think I'll end up replacing those two switches that I mentioned as they are really just junk
redcoats
« Reply #7 on: March 17, 2005, 01:23:50 pm »
Hey intruder check behind the monitor and see if it has a settings board. You may be able to degauss it if it does. Since it is connected to a PC it may just be an oversized PC monitor. And if it is the monitor will have some type of board to mess with brightness, contrast, and degaussing ect.
RayB
  • I'm not wearing pants! HA!
  • Last login:July 10, 2025, 01:33:58 am
  • There's my post
    • RayB.com
« Reply #8 on: March 17, 2005, 02:30:50 pm »
That thing you said you don't know what it is, looks like a power supply to me. The thing not bolted down is an isolation transformer (likely for the monitor).
NO MORE!!
IntruderAlert
    • Intruder Alert
« Reply #9 on: March 17, 2005, 02:33:01 pm »
thanks guys
i wish i had a manual for this machine to help me sort out the wiring
here's the company web site
http://www.expotato.co.kr/
but I dont understand Korean and the "ENGLISH" link doesn't seem to work for me :(
« Last Edit: March 17, 2005, 02:50:28 pm by IntruderAlert »
dek
  • Last login:March 10, 2011, 01:23:33 am
  • Banana Cognac!
« Reply #10 on: March 17, 2005, 04:00:42 pm »
What'd you pay for this?
IntruderAlert
    • Intruder Alert
« Reply #11 on: March 19, 2005, 01:41:42 am »
thanks for the PM dek
i'll let you know if i run across another one of these
...well.. it looks like we're back in business folks
i found and disconnected the faulty wire
I still don't have ALL of the lights and everything working yet but the game is fine
i got a closer shot of that power thingy in the top right corner.
it says SS-2000A
NiN^_^NiN
« Reply #12 on: March 19, 2005, 03:37:53 am »
OMG I LOVE THIS GAME ITS SOOOOOOOOOOOOOO GOOD
Do you know how the game is installed on the pc?
is it a image?
IntruderAlert
    • Intruder Alert
« Reply #13 on: March 19, 2005, 04:27:17 am »
i haven't gotten around to looking at the hard drive yet
maybe i'll connect a keyboard and mouse tomorrow and give it a looksee
it's a Korean version of windows so that should be fun  ;D
IntruderAlert
    • Intruder Alert
« Reply #14 on: March 19, 2005, 04:32:42 am »
this thing says it's 110v / 220v selectable
and I know the PC power supply should be selectable
so the only thing holding me back from switching everything over to 110 is the monitor
.. I don't know much about those flyback transformers
SirPeale
  • Green Mountain Man
« Reply #15 on: March 19, 2005, 07:47:51 am »
Good idea linking your project to your sig.  Don't think I can help much, though.  What's the game like?
IntruderAlert
    • Intruder Alert
« Reply #16 on: March 19, 2005, 02:01:52 pm »
It's this really crazy game about babies competing in various sports? including footrace, electrical jump rope, bull throwing, dancing, swimming from the bottom of the ocean with a ball and chain tried around your leg, slapping, trying to wiggle an octopus off your head, gorilla hunting in a jeep (the other player gets to be the gorilla), trying to stay on a teeter totter board hanging from the bottom of a helicopter while a monkey underneath tries to throw you off balance, long jump onto sumo wrestlers, and I'm guessing some other bizarre levels that we haven't made it to yet.
http://img76.exs.cx/img76/8456/1630002011zl.jpg
the game is strange and fun
I had really planned on buying this just for the monitor to build a MAME cab but now I guess I'll be keeping it like this (at least for a while)
« Last Edit: March 21, 2005, 11:03:34 am by IntruderAlert »
IntruderAlert
    • Intruder Alert
« Reply #17 on: March 21, 2005, 11:04:07 am »
there are some settings on the setup screen that I don't understand
in the game options there is a setting for "level up term" and "level down term" both can be set from 1-5 and OFF
There is also settings for "rest maximum" that can be set 1-5 and a setting for "rest skip stage" that can be set to "on" or "off"
GGKoul
  • Cheesecake Apprentice
« Reply #18 on: March 21, 2005, 11:10:39 am »
I wouldn't MAME it.  As some people on this board would like to purchase the game from you.   ;D
IntruderAlert
    • Intruder Alert
« Reply #19 on: March 22, 2005, 12:54:41 pm »
Yeah.. since it's kind of rare I guess I shouldn't part it out like that.
Now that I have it working I think I'll just finish cleaning it up and getting all of the lights and everything working and keep it for a while.
I might end up selling it once the novelty of it has worn off a bit and build a vertical MAME to take it's place  :)
IntruderAlert
    • Intruder Alert
« Reply #20 on: March 22, 2005, 03:22:38 pm »
I'd like to keep this all original if possible
The original joysticks are a little creaky/squeaky
I looked for a guide on reconditioning and maintaining joysticks but I can't find anything =(
SaiNRuB
  • Last login:November 26, 2024, 07:30:53 pm
  • Pluck your magic twanger, Froggy!
« Reply #21 on: March 22, 2005, 10:13:39 pm »
Its really nice, that should liven up a corner in your gameroom :)
paigeoliver
  • Awesome face!
« Reply #22 on: March 24, 2005, 07:23:20 am »
Just replace the joysticks with another set with the same bolt pattern. I severely doubt Andimaro put any thought into what type they were using. They are likely just a common Asian joystick, you can probably order the exact same ones from someone for $10-$15 each. If you can't find the EXACT ones, you can certainly find the same bolt pattern.
IntruderAlert
    • Intruder Alert
« Reply #23 on: March 24, 2005, 09:24:32 am »
The name on the top is "crown"
tommy
« Reply #24 on: March 24, 2005, 10:47:48 am »
That things gotta sound pretty good with all those speakers,  how did you come across that cab.
IntruderAlert
    • Intruder Alert
« Reply #25 on: March 24, 2005, 12:24:09 pm »
An arcade nearby was clearing out a few arcade machines
there was only one of these though
It's plenty loud
I'm happy with it just barley turned up
My original plan was to part out the whole thing and use the monitor on a MAME cab and use the sound system in a video jukebox
but due to the enthusiasm I have received over the game I guess I'll just clean it up a little and sell it when I get tired of it
the sound system would have made a cool jukebox though
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #26 on: March 24, 2005, 09:03:34 pm »
wow...that's a freaky machine. I would keep it....it seems too unique between the visual design; pc inside etc. etc. to take that thing apart.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #27 on: March 25, 2005, 08:57:29 pm »
I bet he is in LA...only there do you find these cool import game cabs.
unclet
« Reply #28 on: March 26, 2005, 07:48:20 pm »
The low design and speakers in the front would make this type cabinet a nice jukebox ..... although I support not parting out the machine as well.   I would really like to play that game to test it out to see if my kids would like it .....  I guess this game is not in Mame yet, so maybe Mame might be interested in some of the stuff related to this game.
paigeoliver
  • Awesome face!
« Reply #29 on: March 26, 2005, 08:42:59 pm »
It will be a long time before any PC based games will ever be in Mame, mame can't even emulate the old 386 and 486 based arcade games yet, much less Pentium 2 and 3 based games.
obiwan
  • Last login:April 03, 2005, 05:52:05 pm
« Reply #30 on: April 03, 2005, 05:52:26 pm »
that's a neet game ! i wouldn't touch any part of it ,leave it the way it is and just build another cab !! you don't see games like this all the time!
