Author Topic: Someone cut Plexi/Lexan in SJ CA area?  (Read 2116 times)
albert_c
  • Last login:April 06, 2010, 03:57:07 pm
« on: March 14, 2005, 07:42:47 pm »
Does anyone know where I can get some Lexan/Plexi cut for my MAS arcade controller without getting ripped off?  I haven't had any success.  Any help would be appriciated.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re: Someone cut Plexi/Lexan in SJ CA area?
« Reply #1 on: March 14, 2005, 09:25:59 pm »
Have you tried tap plastics?  Just curious if thats who ripped you off before?
albert_c
« Reply #2 on: March 14, 2005, 09:33:14 pm »
You must  be psychic!   :P
The wanted 40 bucks for 9 holes.  What kind of crap is that.....
geomartin
  • Last login:July 13, 2017, 08:55:24 am
« Reply #3 on: March 14, 2005, 11:10:13 pm »
Time is money. ;D  It's not so hard to do yourself, but unless you plan on making more than one the tools could end up costing more than the $40.  Really just depends on if it's a one time deal or not.
Geo
Please!  Give me the good news first!
Goz
  • KOTA
« Reply #4 on: March 15, 2005, 12:24:04 am »
For some bizarre reason the prices vary from TAP locations for the same work. The one on the Alameda has been the most cost effective of the work I have had them do.
Same holds true for other business' in SJ like Kinko's price ranges quite a bit from location to location as well for backlight film prints.
Good Luck and if you find a better place let us all know.
-Goz
albert_c
« Reply #5 on: March 15, 2005, 12:32:22 am »
I work across the street from the one on the Alameda.  That's the one that gave me the 40.00 quote.  Could I use a table saw to cut the shape?  What kinda bit would be best to use on the holes?  Does the lexan break easy, do I have to be super careful with it?
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #6 on: March 15, 2005, 02:15:58 am »
Where can you buy Lexan? I used plexiglass on my control panel and it cracks easily and scratches even more easily. So I'm thinking about moving to Lexan.
Joseph Elwell.
Goz
  • KOTA
« Reply #7 on: March 15, 2005, 06:15:52 am »
Joseph Elwell.
Home Depot
-Goz
albert_c
« Reply #8 on: March 15, 2005, 02:08:42 pm »
That's where I bought mine but they have a big ass sign over the lexan "we do not cut plexi"
damn....
Anyone around here have the know how and tools to cut it?  I'm willing to pay 10 bucks  :'(
Rip
  • Last login:September 26, 2008, 05:28:16 pm
  • Product of the 80s
    • Curret lineup
« Reply #9 on: March 16, 2005, 02:58:52 am »
I abandoned plexi long ago as it ALWAYS cracked on the last hole I drilled  :'(.
Lexan is about 50% more expensive but will never crack, and is easy to work with.  You simply need to score it deep enough with a straight edge and sharp blade (Xacto etc) and it'll snap along the straight edge if you apply enough bending pressure against a solid edge.
As for holes, you can buy a 1 1/8" Blu-mol bi-metal hole saw.  It is not a spade bit but instead looks like a drill bit with a tube on the end.
search for "blu-mol 6533" on homedepot.com.
Not only will it cut through Lexan (like butter) but will cut through steel control panels easily enough too (be sure to use a corded drill, my rechargable dies on steel hole drilling).  They are guaranteed for life!
Recreating the 80s, one cab at a time.
Gallery
albert_c
« Reply #10 on: March 16, 2005, 12:05:59 pm »
Thanks for the info.  I'll give it a shot.
Dave_K.
    • Arcade Fever
« Reply #11 on: March 16, 2005, 12:22:14 pm »
Searching homedepot brought up 3 blu-mol products, and only 1 has a 1 1/8 bit and says it will also cut metal...but its the most expensive.  Is this the correct one (for 69.97)?
« Last Edit: March 16, 2005, 12:24:24 pm by Dave_K. »
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #12 on: March 16, 2005, 01:07:34 pm »
Seems right, and remember, you can never have too many tools.
usedelectronics
  • Last login:January 06, 2019, 02:57:37 am
« Reply #13 on: March 16, 2005, 02:24:38 pm »
Keep in mind that plexi is actually more scratch resistant than lexan.
Lexan's advantage over plexi is it's resistance to cracking/shattering.
Rip
    • Curret lineup
« Reply #14 on: March 17, 2005, 12:16:55 am »
That is the whole kit...I don't know if HomeDepot's search is regionalized, but my search for "blu-mol 6533" came up with a 1 1/8" bit for $7.79 ... this is the one I use often
Gallery
albert_c
« Reply #15 on: March 17, 2005, 12:33:00 am »
I used it on some plexi glass.  totally cracked it.  I'm going to give some lexan a shot.  Should be easier to work with.  Thanks guys for the help
brained
  • Last login:October 07, 2025, 10:17:53 am
  • Raised by Atari
    • Nux
« Reply #16 on: March 17, 2005, 02:30:15 pm »
if you're going to cut or drill plexi be sure to clamp it down to a piece of wood!! some people use the sandwich method I just clamp it down, that way it wont break. If you want to shape the plexi to match your cp, get yourself a hacksaw and let it rip, then take a very high grit sand paper and smooth the edges.
I hope this works for you
