Author Topic: GP-Whiz? Anyone?  (Read 1221 times)
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
GP-Whiz? Anyone?
« on: March 14, 2005, 06:22:40 pm »
Is the USB GP-Whiz from KeyWhiz the same as the KeyWhiz, just with an USB input instead of a keyboard input?
Hoagie_one
  • Um....whats a cabinet
Re: GP-Whiz? Anyone?
« Reply #1 on: March 14, 2005, 06:34:55 pm »
its recognized as a joystick instead of a keyboard
NoBonus
« Reply #2 on: March 14, 2005, 06:41:11 pm »
Does that make it any better or worse (other than it does not use the keyboard port)?
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #3 on: March 14, 2005, 09:51:28 pm »
As is typical with most any question, it depends....
It's fine for any game/platform which expects a gamepad as the interface or can be configured to use a gamepad over keyboard functions.
However, if you have a particular game that cannot be redefined, you are limited to creating a workaround that will cause a joy function to be converted to a keypress, ie: joytokey for example.
It is *not* a USB interfaced Keywhiz. It is recognized by Windows as a Gamepad with a joy and x number of buttons.
However, it is a great product for what it is designed to be and would work perfect for MAME applications.
I trust the above....
....makes sense
....helps.
markrvp
  • NFL Expert
« Reply #4 on: March 14, 2005, 11:12:38 pm »
I just hooked one up tonight and it works great.  Games in MAME need to be set to allow joystick input.  The GP-Whiz defaults map out to the MAME defaults for joystick 1 (Up Down Left Right - button 1=Joystick Button 0, etc.)
It requires a little more preplanning and setup in MAME than a keyboard encoder, but sure works great when it's setup.
Tommy Boy
  • Last login:April 13, 2010, 04:13:56 am
« Reply #5 on: March 14, 2005, 11:25:41 pm »
Is that all we get?  Surely you can give us a better review than that  :)
markrvp
  • NFL Expert
« Reply #6 on: March 15, 2005, 12:42:34 am »
I promise to give a better review when I've had a little more time to play with it.  I will add another joystick and some more buttons to the panel it's on.  Then I'll  move the panel among three different MAME computers and make sure it works plug-and-play on all three.
