Author Topic: A pair of Omni-Stick questions  (Read 1230 times)
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
« on: March 14, 2005, 11:21:55 am »
Here are my questions about the Omni-Stick at www.groovygamegear.com
First, how does this play in 4-way mode?
Second, has anyone used a J-stick or Happ Super and made a 4-8 way switch like the one on the Omni-Stick?  It looks like a simple metal plate with a bar to switch from 4 to 8 way.  Has anyone done this? and does anyone produce something like this?  Here's a photo of the underside of the Omin-Stick.  If anyone has another photo of the switch mech that would be greatly helpful.
Stingray
Re: A pair of Omni-Stick questions
« Reply #1 on: March 14, 2005, 11:26:40 am »
Great! I love that stick. Can't recomend it highly enough.
-S
evlbeaver
  • Last login:February 13, 2011, 10:42:53 pm
« Reply #2 on: March 14, 2005, 01:39:13 pm »
I modified a J-Stick to be switchable.
I filed down the bump in the 4/8 way switch so that the lever would slide freely without lifting up. Then I drilled a small hole in the end of the switch lever and made a loop with stiff wire.  I then attached this to a screw-eye that was attached to a dowel rod.  I drilled a hole in the left side of my control panel and inserted the rod.  Then I put a knob on the dowel.
The end result?  Pull the plunger out for 4-way and push it in for 8-way.
This was before the J-Stick plus.  If I were doing it over I would have bought the J-Stick Plus instead.
NoBonus
« Reply #3 on: March 14, 2005, 01:45:05 pm »
That's brilliant!  I have a J-stick (regular one) and I like it a great deal...  I like the side push/pull idea... that REALLY gets my brain going.  THanks!  BTW, do you have any pics of that?
evlbeaver
« Reply #4 on: March 14, 2005, 01:56:23 pm »
Sorry that was a modified T-Stick.
« Last Edit: March 14, 2005, 01:57:59 pm by evlbeaver »
evlbeaver
« Reply #5 on: March 14, 2005, 02:06:56 pm »
Here is the link to the old thread with pics:
http://forum.arcadecontrols.com/index.php/topic,12927.0.html
