Author Topic: Home made video amplifier question  (Read 1308 times)
knuttz
  • Last login:January 08, 2025, 05:36:02 pm
« on: March 14, 2005, 12:15:09 am »
I've just constructed the video amplifier circuit found on:  http://www.mameworld.net/pc2jamma/hardware.html (second schematic down) and I have a question.  I tested this with a function generator and o-scope at school and found that it puts about a 3 volt positive DC offset on the output signal.  That is the output signal is the desired ~ 4volts peak to peak but it swings between 1 and 5 volts.  This is with a .7volt p-p (no DC offset) input signal.  I know that this offset has to be there because the circuit operates from 0 to 5 volts.  My question is will this damage my monitor or affect my picture quality at all.  I didn't want to try this before asking about the offset.  Attached is the schematic of the circuit from the pc2jamma page.
"Look at all those hamburgers. You can't eat all those hamburgers you stupid fella, OH GEEZ!" "OH he's gonna do it! He's so rediculous."
