Author Topic: MameWah layout designing ?  (Read 1699 times)
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« on: March 12, 2005, 04:12:41 pm »
I tried to make a  background image for mamewah layout,it was a Jpeg
format file i compose in adobe photoshop.There was no background image when i load mamewah.1024x768 was the resolution for both
mamewah.ini and layout.lay.
any help ...
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re: MameWah layout designing ?
« Reply #1 on: March 12, 2005, 06:46:41 pm »
need more details, what did you name the background pic for example, etc...
look at the doc.
jcrouse
    • CPViewer
« Reply #2 on: March 13, 2005, 08:54:32 am »
Well first off you need to start the layout designer and point to the background image using the menu background/image. Then you background image needs to be named properly. Lets say your ini file in the ../mamewah/ini folder is called 000mame.ini, you layout needs to be named 000mame-main.jpg and you layout needs to be named 000mame.lay. The entire naming convention is explained in one of the docs.
Good Luck,
John
