Author Topic: Hantarex Polo 27" help needed  (Read 1794 times)
menace
« on: March 10, 2005, 01:00:07 pm »
I decided to have another go at this so i recapped it and dropped in a new flyback.  The good news is I get a picture, the bad news is it looks like this :
Basically for the first few seconds (maybe 5) I get the first image--bright with scanlines and no adjustments have any effect, then it goes to the next pic with a snap sound and it stays like this until you unplug it and plug it back in.  Any ideas?
Ken Layton
  • Guru
  • Technician
Re: Hantarex Polo 27" help needed
« Reply #1 on: March 10, 2005, 06:29:49 pm »
It could be that your monitor's B+ voltage is too high causing it to output too high of a high voltage to the tube. Do you have a picture tube rejuvenator (restorer/analyzer) handy? If so I think you might a have short in the tube that the rejuvenator would definitely be able to cure.
menace
« Reply #2 on: March 10, 2005, 07:39:19 pm »
Yeah I checked the voltage at TP6 and she reads 138VDC for pic1 one but drops to 126VDC for pic 2--so there's definitley something going on there--guess i'll break down and get me a rejuvenator--figure it's going to cost me at least 50-100$ to get it done, might as well put that towards a rejuvenator.
menace
« Reply #3 on: March 12, 2005, 08:05:59 am »
Would a rejuvenator help in the case where I get no continuity between any of the neck pins except 9,10 (heater)
Ken Layton
  • Guru
  • Technician
« Reply #4 on: March 12, 2005, 11:29:44 am »
There should not be any continuity between any of the pins except the filament (heater) pins 9 and 10.
If you're looking for a short with just a multimeter you may not find it. Sometimes a short/leakage inside a picture tube only occurs during actual load/operating conditions which of course a rejuvenator would pickup and most of the time would correct.
menace
« Reply #5 on: March 12, 2005, 03:30:30 pm »
Ah! ok thanks ken! I was confused by my lack of a "giveaway" indicator there--ebay here I come  :D
