Author Topic: HUGE 34" Monitor in Atlanta  (Read 1397 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: March 10, 2005, 10:50:20 am »
A huge monitor for sale in atlanta.  Below are the specs and a picture of the same model.
I will be taking actual pictures of the monitor tonight.  This is VERY heavy so only local pickup in Atlanta.  To give you an ide of how big this is the screen, just the CRT is 32" diaganol.
The monitor housing is over 3' wide and 3' tall.
$100 even.
Mitsubishi - xc3710ss
Monitorworld had this info:
Model:       XC3310
Max Resolution:       800 x 600
Sync Type:       Composite, Seperate
H Freq/ V Freq:       15-35KHZ / 40-75HZ
Tube Manufacturer:
Monitor Type:       Multisync/Multiscan
Tube Model:
Tube Size:       33
Connector:       3 BNC
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
Re: HUGE 34" Monitor in Atlanta
« Reply #1 on: March 10, 2005, 11:58:01 am »
will that work with ArcadeVGA?
RetroJames
« Reply #2 on: March 10, 2005, 12:00:01 pm »
Not sure, there are video inputs as well as RGB on the rear.  I am going to fire it up tonight on the RGB.
