Author Topic: Name That Monitor's Problem!  (Read 2512 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: March 08, 2005, 10:52:34 pm »
I am auctioning a few 19" monitors, all have some issues.  Take a look...
<shameless promotion>(feel free to bid)</shameless promotion>
But more importantly, see if you can diagnose that problem.  I am curious as I was planning to troublshoot and fix them, but as you know with this hobby, sometimes you need the $$ right away.
http://search.ebay.com/_W0QQsassZ787sellpro
Mostly I am curious about these two:
(#1) - Horizontal Line - http://tinyurl.com/7yukh
(#2) - Half Screen - (Sorry no pic, but read description) - http://tinyurl.com/6txy7
Ken Layton
  • Guru
  • Technician
Re: Name That Monitor's Problem!
« Reply #1 on: March 08, 2005, 11:47:51 pm »
Both those have bad vertical output transistors. They are mounted on the twin aluminum heat sinks.
RetroJames
« Reply #2 on: March 09, 2005, 01:15:47 am »
Ken, you should start a arcade newbie monitor help line online.  $1.00 per question.  I owe you two. (actually much more) whats your paypal?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 09, 2005, 02:22:59 am »
Sometimes resistor R313 (470 ohms, 7 watts) which is mounted vertically in the corner of the board goes open circuit which also kills vertical deflection. Capacitors C313 (100 uf @ 160 volts) and C701 (1000 uf @ 25 volts) cause vertical height problems when they go bad.
My paypal is KLayton888@aol.com
wakerlet
  • Last login:September 25, 2007, 11:37:53 am
  • 1-2-3-4..thats the combination on my luggage
« Reply #4 on: March 09, 2005, 08:45:25 am »
RetroJames
« Reply #5 on: March 09, 2005, 08:56:55 am »
PayPal sent!   ;)
Ken Layton
  • Guru
  • Technician
« Reply #6 on: March 09, 2005, 10:09:07 am »
Wakerlet:
You could buy one of the Wei-ya replacement chassis that retrofits the Electrohomes from either one of these guys:
http://www.home.earthlink.net/~video1963/id1.html
http://yp.bellsouth.com/sites/alvaamusement/
One of those chassis would repair your old CAO and it comes with full instructions. Plus the replacement chassis uses negative sync!
wakerlet
« Reply #7 on: March 09, 2005, 11:15:16 am »
Wakerlet:
Just ordered one from Alva yesterday, thanks.   It only cost ~$58 with shipping for the G07 replacement.  Seriously, if you want the CAO chassis let me know (free for you).  Otherwise it'll go up on ebay.
-Todd
Ken Layton
  • Guru
  • Technician
« Reply #8 on: March 09, 2005, 11:21:50 am »
No, I don't need it. Thanks for the offer though. :) Go ahead and ebay it and hopefully it'll bring you some money to offset what you've spent on the CAO. Let us all know how your new Wei-ya chassis works & how you like it.
