Author Topic: Odd *new* JukeWin problem  (Read 1955 times)
sac01
  • Last login:February 27, 2016, 08:15:22 am
« on: March 06, 2005, 07:15:32 pm »
Question for ya Chris, I've been running your jukebox software for years now, and love it... Ok, I Just started having an odd problem with the latest Jukewin version.. it's been on my cab since you released it, and working fine (win xp).. Today i ran a registry cleaner, which found a bunch of junk and deleted it...lol..Now all the songs on the jukebox are showing up twice...I tried deleting the data files and rescanning, but it still does the same thing...Is there anything that's stored in the systme registry i could have accidently deleted??
thanks alot for all the great work
sac
Chris
    • Chris's MAME Cabinet
Re: Odd *new* JukeWin problem
« Reply #1 on: March 06, 2005, 09:15:46 pm »
I don't do anything at all in the registry.  If you delete the contents of the DATA folder, it will rescan everything from scratch.
Is it possible you're scanning directories twice?  WinCab has an internal setting of SongPath=. to include the jukebox directory and anything below it.  So if you have a SongPath1=c:\Jukebox and that's where the jukebox is installed, and all your music is in directories under C:\Jukebox, all of your songs will be scanned twice.  They still shouldn't show up twice, though.
Please delete the contents of the Data directory, go into jukebox.ini and set DebugLevel to 5, run the jukebox, and if you still get double songs, send me the resulting jbdebug.log.  Actually, if your executable is still called jukewin, you're using an older version and the log file will be called allegro.log instead. Or you're still using 2.41, in which case there won't be a log file at all...
--Chris
--Chris
sac01
« Reply #2 on: March 06, 2005, 09:33:05 pm »
sorry, yeah i missnamed the exe, it's the latest i believe
the weird part is, i looked at the database in notepad, and all the songs are only in there once, but it shows them twice in the display when it's running
it just started today
not sure what i could have messed up.  I'll run the debug, and post it
thx
sac01
« Reply #3 on: March 06, 2005, 09:48:54 pm »
I PM'd the log, since it was quite large O.o
it's still doing it also.
i know it's something i messed up earlier today...Be damn if i can figure out what
sac
sac01
« Reply #4 on: March 06, 2005, 09:50:33 pm »
OH!
i just tried what you said.. i remarked out the songpath in the .ini since the exe and the songs are in the same parent folder, and that did it...Now the weird part is...why did it just start doing it today?
hmmm
lol
