Author Topic: Happs Black Pica Vinyl and un-primed MDF...  (Read 4635 times)
SideShow Rob
« on: March 02, 2005, 07:22:46 pm »
Hi Guys,
I'm about to start work on my second cabinet...hopefully avoiding the pitfalls experienced with the first!
I was never 100% pleased with the Black Gloss Paint finish on my first cabinet...and as this cabinet is (hopefully) going to be much smaller than the previous cabinet, I am planning on covering the sides, front, and top with Happs Black Pica Vinyl.
What I would like to know...is the adhesive strong enough to apply to unprimed MDF...or would people recommend priming the surfaces beforehand? (Or even priming and top-coating, before applying the Vinyl...)
Many thanks for your time...
Rob.
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
Re: Happs Black Pica Vinyl and un-primed MDF...
« Reply #1 on: March 02, 2005, 07:26:26 pm »
I pearsonally would'nt prime it. You want the adhesive sticking to the wood not paint that could flake off. I would reccomend sanding it with course sand paper to rough it up a little.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
SideShow Rob
« Reply #2 on: March 02, 2005, 07:44:47 pm »
Thanks Shape D...
That's the response I was hoping for...I'm all for less work...
But if anyone else has advice contrary to this, or indeed, can confirm that unprimed is okay...please let me know.
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #3 on: March 03, 2005, 03:10:01 am »
un-primed mdf here too & the viny is still holding stong
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
« Reply #4 on: March 03, 2005, 07:13:28 am »
Yep, shouldn't be a problem. I've even used it on powder coated metal and its still holding strong.
SideShow Rob
« Reply #5 on: March 03, 2005, 01:04:44 pm »
Thanks a lot guys...that's great news, and should shave a weekend off building the cabinet.
woodywood
  • Last login:February 19, 2006, 11:03:11 am
« Reply #6 on: March 03, 2005, 10:07:16 pm »
Hey I might use this for my cabinet. How did you guys cut it? Is it basically a laminate, so do I use a router?
SideShow Rob
« Reply #7 on: March 04, 2005, 06:20:23 am »
You can check the details here:
http://www.happcontrols.com/vending/acesor/49057200.htm
The item I am going for is:
D 49-0474-00
