Author Topic: Tv for monitor  (Read 2111 times)
Voodooray
  • Last login:July 24, 2006, 04:52:41 am
  • Load ya swine!!!!!
Tv for monitor
« on: February 28, 2005, 02:19:00 pm »
Hi gang.
Fairly new to this and i was wondering if anyone could help me out?
Would i be able to use a tv (pal uk, don't know if that makes a difference or not ???) as my monitor? Will it work on the tv out from my graphics card on just a scart lead or do you need a monitor plugged in as well?
I couldn't afford a huge monitor but i can get a 21" or 25" tv for nothing.
Thanks dudes.
Voodoo Ray.
88 Acid Revival, Safe!
Voodoo Ray.
RoboG2
  • P&R
  • Last login:August 15, 2008, 10:21:26 pm
Re: Tv for monitor
« Reply #1 on: February 28, 2005, 03:05:57 pm »
You defienetely can use it as your monitor (SCART is supposedly very close to a genuine arcade monitor connection), and I do not believe that you have to have another monitor (in US you don't).  Don't want to lie about it and be wrong. ;)
Voodooray
Re: Tv for monitor
« Reply #2 on: March 02, 2005, 12:39:35 pm »
If your lying.....i'll be back 8)
Serioussly, thanks for the info boss, much appreciated!
Voodoo Ray.
Voodoo Ray.
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
Re: Tv for monitor
« Reply #3 on: March 02, 2005, 01:26:03 pm »
I run 2 set ups using TV Out. The first runs a radeon 9200se which plays out to both a 24" TV and a 19" monitor at all times . The other uses a Nvidia Vanta TNT2 M64 which will either give TV Out or Monitor and not both together. I run this one on a TV only with no monitor connected.
Also check the website relating to your Graphics card and make sure you have the correct driver as i found the generic Nvidia driver did not enable the full features of the TNT card.
tetsujin
  • Last login:April 10, 2007, 05:51:25 pm
  • My controls will have programmable button labels.
    • My Homepage
Re: Tv for monitor
« Reply #4 on: March 04, 2005, 04:42:32 pm »
I have a different question about TV-Out for arcade games...
I tried some TVs with an S-Video cable and my Powerbook, and the reds were bleeding all over the place.  Red ghosts looked bad, red text was illegible.  Is this par for the course with TVs?
---GEC
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
Re: Tv for monitor
« Reply #5 on: March 05, 2005, 11:24:40 am »
The general rule with Scart is to get a very good quality, well shielded cable. Budget scart cables can cause havok with your picture (white-outs, colours bleeding etc).
A good quality cable in blighty will set you back around
I didn't touch it....honest!
markb
  • The One and Only.
Re: Tv for monitor
« Reply #6 on: March 06, 2005, 07:18:03 am »
Text usually is pretty hard to distinguish on a TV, however as previously posted try a new scart and if possible try using colour correction on the software for your TV-Out card. This may be able to sort out the problem.
