Author Topic: Trackball - Mame Analog Settings  (Read 2328 times)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« on: October 29, 2002, 09:29:27 pm »
Yeah, I know.. it's been asked a billion times.  I *did* search the forum, but didn't find much even though I KNOW it's been covered here before.
What settings are people using with a 3" arcade trackball in MAME Analog settings?
I know its recommended if you're doing to mouse hack to disable mouse driver acceleration.  Any other tips?
What are some good ballpark settings for different trackball games?
I found that some games have a dip switch setting for differnt trackball (sizes?) Capcom bowling for instances has a 1, 2, 3, and 4 setting... I found 2 worked well for me... but I don't konw what "2" means =P
*shrug* any and all tips guidelines are appreciated.
rampy
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Trackball - Mame Analog Settings
« Reply #1 on: October 30, 2002, 12:00:45 am »
I usually find that games work best with the analog controls --> sensitivty at about 2 to 2.5 times higher than a normal PC mouse (ie: the default mame setting) with 3" TBs.  Of course, normal PC mice vary too, so this is just a ball park number.  Too bad you can't edit these settings outside of mame like you can with the ctrlr.ini inputs. :(
Robin
Knowledge is Power
Chris
    • Chris's MAME Cabinet
« Reply #2 on: October 30, 2002, 10:08:09 am »
What's worse is that you'll lose all your tweaks when you update MAME...
--Chris
