Author Topic: Help with a PlayStation to USB adaptor  (Read 924 times)
thex
  • Last login:February 27, 2005, 04:18:02 am
« on: February 25, 2005, 09:35:29 pm »
Hi folks,
Details:
NoName PlayStation to USB adaptor
PlayStation DualShock2 Controller
Street Fighter 15th Anniversary Collection Nubytech Arcade Stick.
I have myself a PlayStation to USB adaptor, only problem is that I cannot use the D-pad on any games.  Under control panel -> game and controller settings, the D-pad comes up as "Pov Info".  The thumbsticks work okay (they are designated to x/y axes and slider/rz axes respectively).
So I did some googling and figured that to get the D-pad working, I'd need to disable the Analog button on the PlayStation controller.  But problem is, the red light indiciating "Analog" is always on even if I push the button.
So I opened up the adaptor and found no bridged solder connections or dry points.  But what I did find was a solder point which had not been used.
                                        ________\/________
                                        \ o o o | o o o | o o o /
Its not one of the standard 9 pins but its located at the top of the input.  Sorry for the crude graphics.
I decided to learn how to fix it first to
a) save some money buying another adaptor
b) learning a bit.
Thanks in advance
LPZ
  • Last login:April 11, 2015, 01:55:21 pm
  • 2nd place is the first loser!
Re: Help with a PlayStation to USB adaptor
« Reply #1 on: February 25, 2005, 09:58:16 pm »
thex
I also have a generic playstation to USB adaptor and mine works flawlessly since I got it 1 year ago.  I am assuming that you have tried troubleshooting your joystick with a playstation, and it functions properly.  The only advice I would give you is to properly calibrate the joy in windows.  If you want, I could take my unit apart, post some pics of it if that would help any.
Dual 50 Caliber Continuous Fire Leon Type Machine Guns......OH YEAH!!!!!
thex
« Reply #2 on: February 27, 2005, 04:18:02 am »
yup I tested all the controllers on a PlayStation and they work fine =(
If you don't mind opening your adaptor that'd be a help. Thanks
duffjr
  • Last login:January 19, 2012, 05:50:14 pm
  • There is no dinosaur name ending in PUSS.
« Reply #3 on: February 27, 2005, 07:16:55 am »
this is from your other thread in consoles.
hey, you should be able to use both the analog and d-pad at the same time.  set your dpad keys with the analog button.  if you cannot control the dpad, i think you have interference from another usb device.  i have a psx controller with analog.  when the analog button isn't pushed, the left analog controls the movement and the dpad does nothing.  when the analog button isn't active, the left analog and dpad controls the movement, and the right analog and L1L2R1R2XBAY can control the action buttons.  if you have a usb conflict, what the analog and d-pad can do get mixed up.
make sure the red switch is selected on the side if it has both n64 and psx ports.
LPZ
« Reply #4 on: February 27, 2005, 08:10:31 am »
Now with my controller, when the analog button is pushed, the sticks become the X/Y axes with Z axe and Z rotation support.  The D pad then becomes the POV.  When the analog is not pushed, the D pad becomes the X/Y axes.  Anyway here is a pic of the front and back of my USB controller:
