Author Topic: Anyone ever setup Server 2003? Questions  (Read 1523 times)
Shredder1
  • Last login:October 17, 2022, 12:42:09 pm
« on: February 25, 2005, 05:44:34 pm »
Here's my main question as I'm new to installing this system...
We plan on getting SErver 2003 and installing it on our home computer for a small home office.  But,  we plan on upgrading our current online connection to Verizon FIOS when it gets activated here.
If I install it now with our current DNS settings, will I have to go back and reinstall/setup everything associated with the DNS numbers, or will these items change automatically once we get hooked up to the new service?
I hope that post made sense...and any info is appreciated :).
Neil
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:February 23, 2026, 07:55:20 am
Re: Anyone ever setup Server 2003? Questions
« Reply #1 on: February 25, 2005, 05:53:17 pm »
Not 100% sure I grokked your whole question, but:
You can change the TCP/IP (including DNS) settings on Server 2003 at any time without having to reinstall.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Shredder1
« Reply #2 on: February 25, 2005, 06:04:25 pm »
Yeah, sorry for the confusing question, but for our web hosting buisness, our ISP set up Windows NT 4 for us, so I'm new to this stuff and can't fully explain it.
Thanks for the answer :). Right now, we have Cablevision Optimum Online. and I was concerned that if I installed the server 2003 software, the DNS settings would be 'set in stone' and I'd have to re-install the software when we got VErizon FIOS.
But now that I know I can change them manually, I can get the software and install it early.  The FIOS Service won't be activated for another month or so here in Wyckoff, but I want to get the software early so I can setup and debug any problems that may occur first.  Don't want our customers waiting for a month while I try and debug the problems...
Hope that cleared things up a bit :).
lucindrea
  • Last login:July 28, 2005, 10:06:19 am
  • I dont think I'm a llama!
« Reply #3 on: February 26, 2005, 10:58:13 am »
2003 is locked up pretty tight by default , what i mean is that it doesnt like being used as a workstation .. just loging onto it and installing updates requires disabling a few security mesures , so keep track of what you do so you can re-enable them once your all up to date etc.
but as stated before your failry good to go as long as your not setting up active directory , AD has all sorts of issues with DNS ( must be installed on at least one server in the AD domain/tree ) and it likes to be on static ip's ...
so if your useing it as a workstation you will be fine ( of course you should use 2000 in that case ) but if your setting up a whole domain you could very well run into some ip problems  you CAN go back and change around the ip/dns settings manualy ( this is not a problem for clients as it's all dynamic , but for a AD server it's a bit tricky ) ... i would just double check you backup all data before messing with it.
« Last Edit: February 26, 2005, 11:00:13 am by lucindrea »
Shredder1
« Reply #4 on: February 26, 2005, 06:58:30 pm »
so if your useing it as a workstation you will be fine>>
Nope, not really using it as a work station.  This will be used as a full blown buisness webserver.  And yep, we'll be getting a Static IP with the new service we'll be installing.  First it'll be VErizon DSL, and then when it's activated here, FIOS...
Shredder1
« Reply #5 on: February 27, 2005, 11:21:07 am »
Also, just to be sure... This offer includes the software, it's not just to buy more client access liscences, right?
http://www.newegg.com/app/ViewProductDesc.asp?description=32-102-225&depa=0
So many different versions, I get a bit confused, heh.
« Last Edit: February 27, 2005, 08:11:31 pm by Shredder1 »
