Author Topic: MameWah and other emulators...questions  (Read 1419 times)
Wyluli
  • Last login:February 11, 2013, 06:38:03 pm
  • Stupid Stupid Rat Creatures!
« on: February 24, 2005, 07:52:09 pm »
I have Mame and NES working with MameWah.  I'm working on SNES and Commodore and have a few questions.  Namely, how do you guys go about exiting from the SNES emulator and Commodore emulator and return to the MameWAH list screen?
I'm using Zsnes and when I hit ESC it brings up the menu in the emulator instead of exiting back to MameWah.
Also, not all my Commodore games are showing up.  Only about 100 are showing up in the MameWAH list.  I have the rom_Extension set to just * because there are different extensions (e.g. t64, d64 etc..) is this causing a problem?
Thanks.
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
Re: MameWah and other emulators...questions
« Reply #1 on: February 25, 2005, 06:33:01 pm »
Use the modiefied ZSNES emulator from www.screenshotarchive.com   It has the ESC key hacked in along with others.
As for commodore....I'm still working on that myself.
Brad
D_BIZZZZ
  • Last login:August 16, 2015, 05:51:29 am
« Reply #2 on: February 25, 2005, 07:32:10 pm »
Hi,
Please can anyone tell me how I can run mamewah to automatically launch with a rom/game when it's loaded instead of having to select it first from the menu.
Basically I would like to power up the machine into my fav ROM and then escape back to menu if I wanted to switch to another ?
Is it possible, perhaps a command line switch of some kind ?
Any help would be most appreciated.
DB
Brad
    • www.emuchrist.org
« Reply #3 on: February 26, 2005, 03:34:31 am »
Theres probably a number of ways to do this but why don't you just create a batch file in your startup folder that runs your game in mame  then when you exit it calls mamewah? eg:
c:\mame.exe pacman
wait
c:\mamewah\mamewah.exe
Important that this is not the correct syntax etc...just an idea
Brad
biron
  • Last login:August 20, 2007, 05:09:14 pm
  • Biron
    • my cab
« Reply #4 on: February 27, 2005, 02:30:30 pm »
Uppsala University.
D_BIZZZZ
« Reply #5 on: February 28, 2005, 08:16:42 am »
Cheerz Brad,
I think that may just work,
even without the wait/pause option inbetween
STARTUP BATCH FILE:
mame.exe <switches> <gamename>
pause (requires a button press)
mamewah.exe
Will try this tonight
DB
