Author Topic: Lazarus Error need help  (Read 3399 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: October 27, 2002, 02:33:54 am »
Hi Howard and gang,
Not sure if u got my msg howard because it did not show up in the send box of my email so I will post it here. i apologize if you did recieve it via my email too.
Gettting wacky error in LAZ says
Runtime error '-214746259 (800004005)' Automation Error Unasigned Error
I get it when i try to hit the exit key from a emu. I had to format xp and start over and now i get this error? anyone help me resolve?
Demon-Seed
Re:Lazarus Error need help
« Reply #1 on: October 27, 2002, 08:49:58 am »
Hey
Ok i think it has to do with my skin I may have sortede it out.. but for some reason when i try to run a game it leaves Lazarus up and mame loads but in the background? how do u resolve that one?
Demon-Seed
Fixed
« Reply #2 on: October 27, 2002, 12:04:00 pm »
Well I am very happy got it working great again!! This is the best FE ever! I have 2 questions.. could someone give me a crash course on getting MP3 list to play randomly in Lazarus? I forget how to do it. Also I am running a 950 Duron, would a 1.2 athlon help run N64 smoother?
Just curious as I may swap chips. also only have a geforce 32mb card what would be best? and links to buy?
thanks
Jim
  • Last login:February 11, 2026, 07:46:44 pm
« Reply #3 on: October 27, 2002, 06:08:46 pm »
Hey
Actually it's supposed to do this... lazarus freezes itself, so it isnt' actually using any resources, it just hides the ugly little box until the rom has finished loading.
check your window options in the lazarus.ini to chage this if it really bothers you ;)
Demon-Seed
« Reply #4 on: October 27, 2002, 06:25:02 pm »
Hey
Its not working again.. :( i hit run to run the game and the scrreen goes black?? i have tried all the options what would it be? then i ctrl+alt+del and i see mame is running but lazarus is not responding.
Demon-Seed
« Reply #5 on: October 27, 2002, 06:36:29 pm »
Ok heres some config files. why wont work i have no clue? I have all the files there.. they all show. u hit run and skin goes black like its trying to load but no mame or other emu appears.
DIR.INI
roms=D:\Mame\roms;D:\Zinc\roms;E:\Nes\roms;E:\Snes\roms;E:\Genesis\roms;E:\32x;E:\Turbo\roms;E:\N64\roms;D:\Modeler\roms;E:\Master\Roms;E:\GBA\Roms
Primary Artwork Dir=D:\Mame\
Additional AW Dirs=D:\Zinc;E:\Nes;E:\Snes;E:\Genesis;E:\32x;E:\Turbo;E:\N64;D:\Modeler;E:\Master;E:\GBA
[startvd]
[path]
caption=Mame
useclones=1
searchstrings:5=MAME
filters:
[/path]
[path]
caption=Modeler
useclones=0
searchstrings:5=Modeler
[/path]
[path]
caption=Zinc
useclones=0
searchstrings:5=Zinc
[/path]
[path]
caption=Master
useclones=0
searchstrings:5=Master
[path]
caption=Nintendo
useclones=0
searchstrings:5=Nes
[path]
caption=Turbo
useclones=0
searchstrings:5=Turbo
[/path]
[path]
caption=SNES
useclones=0
searchstrings:5=Snes
[/path]
[path]
caption=Genesis
useclones=0
searchstrings:5=Genesis
[/path]
[path]
caption=Sega 32x
useclones=0
searchstrings:5=32x
[/path]
[path]
caption=N64
useclones=0
searchstrings:5=N64
[/path]
[path]
caption=gba
useclones=0
searchstrings:5=gba
[/path]
[/startvd]
LAZARUS.INI
[Lazarus]
****Raging Dragon initiation file
****This file MUST be setup before you can run RD properly
****Please leave all options and comments in tact.
****turn wordwrap on for most readable results
****Designate the window Style
****1=Solid
****2=Psudeo Translucent (for 9x users)
****3=True Translucent (for 2000/XP users ONLY)
****If your menu won't appear then set it to 1
MenuStyle=1
****The refresh rate of the lists...leave this alone unless you run into problems with the scroll rate.
****the default setting is 100 btw
****The artwork scroll rate determines how fast the artwork will refresh
****keep it equal to or higher than the list scroll or strange results will occur
listScrollRate= 50
ArtWScrollRate= 100
****This is an option for users of the ati mm center.  To use it save two profiles in the settings for your card..... one for the default settings and one or when the fe is launched....
****give the fe scheme a shortcut key ctrl-alt-a (arcade) and the default ctrl-alt-d (default)
****This is useful for switching to tv display automatically
****For more info consult your ati cards documentation on how to set this up
****Put yes for yes and no for no
AtiSwitcher=0
****This is a quick and dirty way for Rd to set your display settings for you...
****It dosen't hold to this res though so make sure all of your emus are configured to match this res..
****Please note that this will force the settings upon windows wheather your hardware supports them or not.
****I HOLD NO RESPONSIBLITY FOR DAMAGE TO YOUR MONITOR OR VIDEO CARD IF YOU USE UNSUPPORTED SETTINGS!!  USE AT YOUR OWN RISK!!!!
xRes= 800
YRes= 600
****Special Note about these......
***if you fill out one (aracde or desktop) and leave the other blank it will use those settings for both so beware!!
****Desktop Frequency
RefR= 85
Bits= 32
****Arcade frequency
RefRA= 60
BitsA= 32
****If you want rd to exit windows upon shutdown then enter yes else enter no
ShutDownOnExit=0
***You can make the command line box appear in different modes when mame starts.  Your options are as follows:
***0=hidden,1=maximized(has focus),2=minimized(has focus),3=minimized(lacks focus), 4=normal,5=normal(lacks focus)
***I don't reccomend any of the modes that lack focus as they can cause display issues for mame.
LaunchStyle=3
[SpecialOptions]
*****This section is going to be ever growing.  It contains quick universal settings for mame that arent easy to setup in the normal mame build.
*****This fixes the capcom games and the battletoads game by sending them the proper aspect ratio in hwstreatch mode.
*****If you know of any other games that need a fix let me know and I'll include a fix for them.
AspectFix=0
*****This checks to see if a game uses a 4way joystick and if it does it turns on steady key for you.
4wayFix=0
[Keys]
UiUp=38
uiDown=40
uiNext50=39
uiPrev50=37
uiConfig=86
uiNextPath=18
uiPreviousPath=17
uiSelect=49
uiExit=67
uiMute=53
uiInfo=54
uiShift=50
**the keycodes to the assigned keys for each function, can be set internally
[Joystick]
'PrevPath
'NextPath
'Select
'Exit
'Mute
'Refresh
'ScreenSaver
'Config
'Random
'Info
*put the appropriate action for each button...
*The list of Possible functions is above.
*the axis are given the up/down/left/right functions by default
and cannot be re-mapped.
b0=     na
b1=     na
b2=     na
b3=     na
--BINGO! Either that, or I was attempting to say "before" but it was too many letters to type--=     na
b5=     na
b6=     NA
b7=     NA
b8=     NA
b9=     NA
b10=    NA
b11=    Exit
[BookKeeping]
*Leave this section be, thanks.
Current Skin=\DemonCade\
ScreenSaverRate=-1
VolRate=0
Mute=0
templi=20
tempdr=9
tempfs=0
random=0
lastMfile=0
MAME.CFG
extension=.zip
path=D:\mame\
exe=lzmame.exe
send rom path=1
send exit keys=0
command line options;
« Reply #6 on: October 28, 2002, 12:33:09 am »
I'm gonna have to smack you on this one........
LaunchStyle=3
see where i DON'T reccomend using any launchstyle modes that lack focus..... that's your problem, change it to any mode that recieves focus.
:P
Demon-Seed
« Reply #7 on: October 28, 2002, 05:30:31 pm »
Hey,
I relize this Howard but I tried them all before and it did not work for me.. tried every single one. once in a while it worked on 3 then stopped. what do u suggest? i left the default and it wont work ? tired the others as well.
JIM
« Reply #8 on: October 28, 2002, 08:26:11 pm »
find one that works well with mame
if it doesn't work for the other emulators then you don't have a wrapper setup for them (which is reccomended for all non-mame emulators)  or it's the fault of the way the emulators displays itself.
when you say "launch a game" that tells me nothing as each emulator behaves differently.
Demon-Seed
« Reply #9 on: October 29, 2002, 10:16:18 am »
Hey,
Ok I am not sure what you need :( It worked before fine, then I formated and reinstalled xp and a few of the drives changed but that was it. SO i adjusted the dirs and configs accordingly. Basically i see the Skin and game list, hit start and the skin goes away but mame never pops on. What would be the best way to resolve it? I tried reinstalling laz from scratch too. Could I be missing something in my files?
thanks for all the help
Jim
« Reply #10 on: October 29, 2002, 11:40:34 pm »
The skin shouldn't go away... if you are getting a blank screen than that is most likely mame.  Check your mame setup would be my guess.
Demon-Seed
« Reply #11 on: October 31, 2002, 10:22:27 am »
Hey,
I am coming home on Friday so I will try again, but no matter what emu I run it does the same thing. Screen (skin goes black) as if its trying to load the emu and then it doesn't appear. If i ctrl+alt+del I see Lazarus is not responding so I close it, then the emu runs?
Jim
« Reply #12 on: November 01, 2002, 01:29:59 am »
Hey,
Jim
It's supposed to do this.... when a game is loaded lazarus locks itself ... if you were to ctrl+alt+del  at any point when a game is running it would tell you that it isn't responding.... it's right it isn't, it's designed that way.  :)
Also this means that the display doesn't refresh, so if something covers it, it will turn the color of the thing in front of it....
in other words your emulator is starting and then it looses focus for whatever reason.  btw while the rom is loading you will NOT get a mame screen if hidden is the display mode.  That part is hidden so while the rom is loading you are going to have to wait.... in other words if you load up metal slug lazarus is going to look like it's "locked up"..... actually it's just waiting for the huge metal slug rom to load, which can take up to a minute on some systems.....  keep that in mind....
So test with pacman, not your latest 30 meg fighter.  :)
i think your problem is a focus issue.... you need to find out what application is stealing focus
some of the geforce screen managment programs are infamous for this, so be sure to disable them.
