Author Topic: TMNT Teenage Mutant Ninja Turtles Monitor Issue  (Read 2595 times)
bluemanop
  • Last login:April 16, 2005, 03:47:21 pm
  • Life is but a game, why not play some?
« on: February 18, 2005, 12:30:55 am »
My friend actually came across a TNMT 4 player machine today. The machine was in good functional order for 150 bucks. I did have a joystick with a minor connection contact problem (I was able to fix this) but the monitor was another story. Although very sharp and bright it has a few vertical dark shadows on the left side of the screen.  These vertical marks tend to be a little less visible when the machine is a little bit warmer.
Could this be from a bad cap or is this just a yoke adjustment situation? Anyone have any ideas?
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
Re: TMNT Teenage Mutant Ninja Turtles Monitor Issue
« Reply #1 on: February 23, 2005, 01:21:18 am »
You should post in the monitor/video forum and hopefully Ken or one of the other arcade-tech gurus will see it and be able to help.
-Ace-
I want my own arcade controls!
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 23, 2005, 09:41:36 am »
Dedicated Ninja Turtle machines came with a Wells-Gardner 25k7191 monitor. It's not a yoke problem, but remember that this monitor is at least 13 years old. You need a capkit for that monitor for sure.
bluemanop
« Reply #3 on: March 06, 2005, 01:22:20 pm »
Do you know where I can get a cap kit and a tool to discharge the power from the tube?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: March 06, 2005, 01:24:58 pm »
Try www.dameon.net/BBBB/ for info on discharging monitors and www.therealbobroberts.com for capkits.
bluemanop
« Reply #5 on: March 06, 2005, 01:58:41 pm »
Anyone ever tell you, You are the man?
« Last Edit: March 06, 2005, 02:17:12 pm by bluemanop »
enchntr
  • Last login:January 23, 2013, 07:49:56 pm
  • All Around Star Wars Nut
    • Power of the Force.com
« Reply #6 on: March 07, 2005, 10:33:36 am »
Sounds like jailbars...as ken stated, a capkit will fix it.
bluemanop
« Reply #7 on: March 08, 2005, 12:22:56 am »
I will take a picture of it, plus I want to verify the model of the monitor just in case it was ever replaced.
