Author Topic: Beatmania IIDX Controller (Konami) does work with MAME?  (Read 6431 times)
Nerop
  • Last login:June 23, 2005, 02:54:34 am
  • Project: Mortal Kombat themed Cabinet
« on: February 16, 2005, 02:32:29 am »
Is it possible to connect the Beatmania IIDX Controller (Konami) for the PS2 via an USB
converter to the pc? And does the controller work with MAME? Any experiences?
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
Re: Beatmania IIDX Controller (Konami) does work with MAME?
« Reply #1 on: February 17, 2005, 11:07:40 am »
I've heard that it does, but I've been too lazy to reinstall the MAME versions of Beatmania.  :-\
kujina
  • Last login:November 04, 2021, 12:07:40 pm
« Reply #2 on: February 17, 2005, 08:32:27 pm »
yas  ;)
Nerop
« Reply #3 on: February 18, 2005, 08:10:14 am »
Hi Kujina,
do you mean "yes" it does work? Have you tested it ? And with which adapter did you try it?
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #4 on: February 18, 2005, 02:02:49 pm »
yeah it works, i use it. although the MAME styles out right now suck anyway i just play ps2 with it mainly. i have a EMS2 usb converter, you just map the buttons as if you were doing joystick controls
"Owens is the ringleader in the ass hat circus"  D K
Nerop
« Reply #5 on: February 20, 2005, 05:18:19 am »
Thanks for all your replies!!
adaaaam
  • Last login:February 23, 2005, 05:07:22 am
  • I'm not a llama!
« Reply #6 on: February 23, 2005, 04:58:12 am »
I suggest you get the PS2 games instead, because there is a slight input lag when using keyboard or joystick on MAME, as such is the nature of emulators, which escalates into major problems when tapping combos on games that require precise input such as music games. What would be 'Great' on arcade displays as 'Good' on MAME, for instance. The PS2 versions however, aren't emulated versions of the games, they're arcade perfect, so no lag whatsoever, no matter how few the milliseconds
Whenever I goto the arcade to play beatmania, I have to readjust my play because I get so used to tapping the notes early on MAME to achieve greats..
« Last Edit: February 23, 2005, 05:01:36 am by adaaaam »
adaaaam
