Author Topic: 3 joys w/o an IPac4  (Read 1609 times)
rhoelsch
  • Last login:August 18, 2018, 08:13:16 pm
  • That...that thing's operational!
3 joys w/o an IPac4
« on: February 15, 2005, 03:34:26 pm »
My cp will be changing in order to accomodate a new trackball and spinner.
Now witness the power of this FULLY OPERATIONAL Mame machine!
Stingray
Re: 3 joys w/o an IPac4
« Reply #1 on: February 15, 2005, 03:39:45 pm »
...can I put the balltop and the player 1 stick on the same connections on the Ipac 2?
That's the way it's generally done. The 4way shares connections with the player 1 8way.
-S
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #2 on: February 15, 2005, 03:42:27 pm »
I dont know anything about the dedicated 4 way, but I know that, as Stingray said, that's how you do it.  When you attach the wires to an iPac 2, you set both joysticks up as Player 1 Up, Down, etc.  This way, whichever joystick you use will send it an UP signal basically.
rhoelsch
« Reply #3 on: February 15, 2005, 04:02:28 pm »
Good to hear--I'm not an electronics expert by any stretch, so I'm always careful not to assume.
cholin
    • Nilok Productions
« Reply #4 on: February 15, 2005, 04:05:37 pm »
One issue that's being brought up alot is the joystick right above the trackball if you plan on using it alot.  Apparently, this is uncomfortable for smaller panels, so beware.  I will also use DB25's when I build my panel because I know someone who works at FutureShop, and well, deals :)
rhoelsch
« Reply #5 on: February 15, 2005, 04:23:06 pm »
Uncomfortable on the part of actually reaching the 4-way or uncomfortable when you do a schwarzeneggarian upwards spin on the trackball and snap a finger bone against the 4 way's shaft? :)
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
« Reply #6 on: February 15, 2005, 04:34:03 pm »
I won't say for sure what Cholin was saying, but in my opinion that is not a great set up for the "schwarzeneggarian" tball moves, especially with v0.92 and all the Golden Tee's...you might want to reconsider...at least give it a thought.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #7 on: February 15, 2005, 06:41:22 pm »
I would love to see a picture of it designed or when your done.
For the Ipac. you just plug both wires into the same screw and its ok?
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
cholin
    • Nilok Productions
« Reply #8 on: February 15, 2005, 07:02:25 pm »
I was talking about the trackball, as IMMark confirmed.  If you look at some peoples' regrets list, they usually mention putting the trackball in a crappy place.  Just beware.
