Author Topic: How does this tickle your fancy?  (Read 2528 times)
Monkeystoe
  • Last login:November 05, 2005, 02:27:52 am
« on: February 14, 2005, 12:19:34 am »
Hi all I am brand new to this MAME-sation (I call it that because I couldn't sleep for days thinking about it.)  This is my first post but have been doing a lot of reading here.  Great  place by the way.
Anyways,  I think I have a great idea for a control panel.  Simply put make it reversible.  Lets say you want  2 player playability with 2-8way sticks 7 buttons a side a track ball a spinner a dedicated 4 way stick and numerous other buttons and possibly even more...more is almost always better as it give more playability for more games.
Try this.  All wiring is usually inside a box that you make for the CP there is a top and a bottom.  Why not give it two tops.  Standard 2 player setup on one side and on the other a trackball and spinner and possibly the 4 way.
  Only a PS/2 or USB cable and possibly a power cable should be coming out the back of the CP so turning the CP over wont require unplugging anything(Just remember to not always turn over the same way could lead to very twisted cables), and all the wiring is still on the inside of the CP
So no needed extra ipac for separate CP's no remapping no unplugging just flip and no more bashing into joystick when using the trackball no stretching for that spinner. You don't even need extra material to build it.  You already have two sides...Use them... Makes perfect sense to me.
What do you think? :laugh:
It is not the answer that enlightens, but the question.
Witchboard
Re: How does this tickle your fancy?
« Reply #1 on: February 14, 2005, 12:22:13 am »
That's a good idea.
« Last Edit: February 14, 2005, 12:23:59 am by Witchboard »
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #2 on: February 14, 2005, 12:24:08 am »
make sure the wires dont twist.. too much
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
Witchboard
« Reply #3 on: February 14, 2005, 12:26:25 am »
Ah.. I think you're talking about flipping, not rotating.  Sorry, mis-read what you were meaning.
Monkeystoe
« Reply #4 on: February 14, 2005, 12:27:35 am »
I suppose you could always very quickly unplug  and replug when you make the flip really should only take seconds if connections are located right at the back of the CP
quarterback
« Reply #5 on: February 14, 2005, 12:31:13 am »
It would be a pretty thick CP, but a pretty interesting idea.
-- Chad Tower
Monkeystoe
« Reply #6 on: February 14, 2005, 12:33:59 am »
I doesn't have to be any thinker if its planned right.  Trackball between the two joysticks on the other side(and their corresponding buttons)
quarterback
« Reply #7 on: February 14, 2005, 12:40:28 am »
-- Chad Tower
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #8 on: February 14, 2005, 01:20:53 am »
Sounds like you'd have lots of bolts showing, but I'm betting I'm just not picking up what you're putting down.
More 'splaining, Lucy, por favor.
quarterback
« Reply #9 on: February 14, 2005, 02:15:53 am »
Check this artwork baybeee!
One side has 2 joys, each with 3 red buttons and a trackball, the other side has a 4-way joy, 5 red buttons and a blue spinner.
-- Chad Tower
quadmasta
  • Last login:May 18, 2022, 03:23:00 pm
    • Approximate Arcades
« Reply #10 on: February 14, 2005, 02:18:55 am »
Seems like he wants something like 1UP, just a whole bunch easier.  I think he's saying he wants to flip it like turning the page on a book.  It'd have to be like 10" thick though.
DrewKaree
  • HAH! Nice one!
« Reply #11 on: February 14, 2005, 05:16:44 am »
Ya, that's what I had pictured in my mind, but I can't figure out how it's going to be done without having the "guts" from the other side showing.
I agree it's a good concept, but have absolutely no idea how you'd hide the undersides of the controls of either side, unless, like was guessed at, it was 10 inches or so.
menace
« Reply #12 on: February 14, 2005, 07:08:11 am »
I get it--its a two sided box with the axis of rotation running from the front of the control panel to the back--easily enough done--use lazy suzy bearings (hollow centers) and run your wires to the pc through there--you would have to make sure it only rotates one direction and reverse otherwise your wires will bind eventually.  You would also have to make the cabinet wide enough to accomodate the diagonal length(corner to corner length) of the control panel or else it will bind on rotation.  If your x-axis parallel to the front of the cab and the y-axis is front to back, rotating along the x would be way simpler and more elegant in turning than having it flip on the y-axis.  less clearance issues for one.  of course if you are just going to pull it up and out and then flip it--ignore the above--then you have to worry about pull out issues (don't we all  ;))
Monkeystoe
« Reply #13 on: February 15, 2005, 06:50:09 pm »
Or....How about this I know modular CP's are not a new idea but usually only 3rd and 4th person extensions onto the sides.  What about a track ball or spinner that can hook onto the front of the existing CP.  You could hide a PS/2 or usb connection under your existing CP for easy hookup.  I just hate not having room when using a trackball.  Nothing worse than being over crowded.
There are quite a few inventive ways of supporting the CP that wont take away from the look of the Cabinet when the add-on is not in use.  Use your imagination.
quarterback
« Reply #14 on: February 15, 2005, 08:22:57 pm »
I'm pretty sure I've seen somebody here at BYOAC who's done exactly that.
-- Chad Tower
pointdablame
« Reply #15 on: February 15, 2005, 11:02:19 pm »
and that is only one step away from modular controls, which are a much nicer setup in my opinion.
As for the flip design.... I see one problem... how would you secure the CP?? If it was on an axis of rotation, you'd have to remove the entire front of the machine to have it rotate around.  If you mean to simply unplug it and flip it manually... how is going to be held on?  Velcro won't be enough in my opinion.  Clamps could work but add a lot more work to the point where I'd say swappable panels are a better atlternative.  No screws or bolts.. that's even more work..  I just can't see how it would be viable although I like the concept.
first off your and idiot
