Author Topic: Suggestions for applying bezel sticker  (Read 2162 times)
mtalkington
  • Last login:May 31, 2010, 05:02:19 pm
« on: February 11, 2005, 07:06:45 pm »
I just received my bezel artwork (with a sticky, adhesive backing) from Mamemarquees.com (who always does a great job), and I'm curious what you guys think is the best way to apply it:
Witchboard
Re: Suggestions for applying bezel sticker
« Reply #1 on: February 11, 2005, 10:16:25 pm »
Is your bezel paper or plastic?
mtalkington
« Reply #2 on: February 12, 2005, 10:20:52 am »
It's a real durable kind of coated paper. It's not going to be messed up on the outside of the glass, if that's what you're getting at. I just don't know which placement is better, or which placement is more "real"....like you would see on a real arcade cabinet
Witchboard
« Reply #3 on: February 12, 2005, 01:05:42 pm »
I have personally never seen anything stuck to the front side of the glass.  Either it was silk screened to the back, or it was taped to the bezel.  I would put it on the bezel to keep it from getting damaged.  You don't even have to peel the stuff off the back to make it stick.  Just lay it in there and sandwich it between the glass and your bezel.
MAME nut
  • Last login:March 18, 2024, 12:33:01 am
« Reply #4 on: February 15, 2005, 10:17:34 am »
Why can't you place the Mamemarquee bezel on top the outside glass???  My understanding is that it is laminated, so it should hold up under normal use.  Wouldn't it give more of the appearance of an old screened-on bezel???
Just curious........
Chris
    • Chris's MAME Cabinet
« Reply #5 on: February 15, 2005, 10:32:18 am »
--Chris
