Author Topic: newbie mame ini help  (Read 988 times)
wrench
  • Last login:August 02, 2024, 03:16:38 pm
  • Another project I couldn't say no to
« on: February 11, 2005, 04:20:29 pm »
I need some handholding on a mame problem,I'm can't get the mouse(trackball) to work in mame games.I know you need to alter the mame ini file and change mouse0 to mouse1,but I don't have a mame ini file in the mame directory and can't figure out how to create it with that cc config thing that the doc file talks about.Can someone please give me a detailed description on how to create this ini file?I've searched the forum and found a few hits but nothing that explains it clearly enough for me to make anything of it.I'm using regular mame(not mame32) with ultrastyle for the frontend.Thanks. ???
Never mind I figured it out,thanks for humoring a newbie,I was trying to run from the run command in the start menu,you need to run mame.exe-cc from a dos command prompt.
« Last Edit: February 11, 2005, 04:50:28 pm by wrench »
