Author Topic: Arcade monitor and setting resolutions for apps.. Anyone wanna help?  (Read 1345 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
Hey all,
I have a WG 7000 series monitor with an arcade vga in the pc...
I am having a hard time picking the correct resolutions for win xp desktop, mamewah game menu, and then getting the .ini's correct for all of the games.
delta88
Re: Arcade monitor and setting resolutions for apps.. Anyone wanna help?
« Reply #1 on: February 16, 2005, 01:23:25 am »
anyone? Buhler? anyone? I have most of the games displaying ok now, but games like mspacman , are to big for the screen and games liek tac/scan flip as well as a few other vert games and some other Vector games......
menace
« Reply #2 on: February 16, 2005, 06:46:38 am »
when using the mamewah res tool, did you delete the resolutions that show up poorly or not all out of the arcadevga resolution list?  Once i did this and hit auto-select, then generate ini, I was good to go.  I used 640x480 for the desktop and mamewah and used the resolution tool for all the games--took some tweaking but finally got it.  if i could access my cab easily i would send it along--maybe I should clean the basement..
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #3 on: February 16, 2005, 10:43:54 am »
Be sure to remove all no 60hz modes.
And the vertical games usually do cut off a little bit.
Later,
dabone
