Author Topic: 27 inch TV for 149.99!!!  (Read 4060 times)
slayj
  • Last login:January 10, 2006, 02:49:56 pm
  • Anybody seen my joy...???!
« on: February 08, 2005, 04:05:09 pm »
Just FYI....>Target has a 27 inch tv for 149.99 that is 25 inches in width, maintains the same audio input when turned off, and will power back on when unplugged/plugged.
Did you know if a frog had wings it wouldnt bump its butt!!!
woodywood
  • Last login:February 19, 2006, 11:03:11 am
Re: 27 inch TV for 149.99!!!
« Reply #1 on: February 08, 2005, 04:20:23 pm »
Man thanks. I was just headed out the door to Best Buy to check out some of their tvs but I have a Target right around the corner. Didn't even think to go there. Thanks again. ;D
slayj
« Reply #2 on: February 08, 2005, 04:21:33 pm »
I just found out that it is no longer at Target at this price, but is now at Circuit City at this price.  Its a Aventure model.....
DemonBrew
  • Last login:December 10, 2014, 06:05:50 am
« Reply #3 on: February 09, 2005, 10:19:15 am »
Here's some specs - I'm assuming this is the one you mean?
Aventura 27" TV (AT427E)
Video
Display type Analog
Built-in tuner NTSC
Flat screen No
Widescreen No
Velocity scan modulation No
Picture-in-picture No
Adjustable color temperature No
3:2 film correction No
Audio
Audio type Mono
Audio enhancement None
Variable/fixed audio output No
Auto volume control No
Inputs and outputs
# Standard component inputs (Front/Rear) 0
# HD component video inputs 0
S-video inputs 1
# A/V inputs (composite) 1
# RF inputs 1
DVI (Digital Video Interface) No
HDMI inputs No
VGA/SVGA input No
CableCard No
Dimensions
Height 22.1 inches
Width 26.0 inches
Depth 19.7 inches
http://www.circuitcity.com/ssm/Aventura-27-TV-AT427E-/sem/rpsm/oid/100260/rpem/ccd/productDetail.do
this space intentionally left blank
slayj
« Reply #4 on: February 09, 2005, 11:19:12 am »
Thats the one............however, the width is not 26 inches.  A rep at Circuit City measured it and it was 25 inches.
hatrick
  • Last login:January 23, 2020, 12:47:20 pm
  • Big Brother is Watching You!
« Reply #5 on: February 09, 2005, 03:34:02 pm »
I picked one of those up on Monday at Circuit City. Mine is indeed 26 inches wide at the widest spot. I haven't tested the picture yet, but it looks like it will make a great monitor for a mame cab.
slayj
« Reply #6 on: February 09, 2005, 03:59:41 pm »
Since it is indeed 26 inches, and I am putting it in the Project Arcade books standard cab which is 26 inches, do you think there will be a heat problem?  Should some fans be placed in the rear for circulation?  Keep in mind that I cannot widen the cab at this point.
tetsujin
  • Last login:April 10, 2007, 05:51:25 pm
  • My controls will have programmable button labels.
    • My Homepage
« Reply #7 on: February 09, 2005, 05:32:19 pm »
Aventura?
If this is the one I'm thinking of, the picture looked pretty poor...
---GEC
hatrick
« Reply #8 on: February 10, 2005, 01:02:47 am »
TheRCGuy
  • Last login:March 20, 2005, 07:24:45 pm
« Reply #9 on: February 10, 2005, 03:23:29 pm »
Thanks for the info!
hatrick
« Reply #10 on: February 17, 2005, 04:55:38 pm »
I've had mine up and running in my cab for about a week now and I have no complaints about the quality of the s-vid picture. Of course windows is a bit hard to read, but that's to be expected.
For the price ($149) I have no complaints.
Witchboard
« Reply #11 on: February 17, 2005, 11:34:54 pm »
Too bad it doesn't have component inputs.  I may have picked one up.
