Author Topic: Television Problem  (Read 1164 times)
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
Television Problem
« on: February 07, 2005, 10:53:14 pm »
Hey Guys, thought i might ask in here because you guys seem to know what your talking about.
I have a Mitsubishi 13' Television from 1993......
Over the past six months its started to have problems. When i turn on the tv, the image is crunched into the middle of the screen, making a widescreen sorta  smush with the image making it unwatchable. 5-10mins after the image becomes clear. Its like it needs to warm up for it to work. Anyone know the issue?
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
menace
Re: Television Problem
« Reply #1 on: February 08, 2005, 07:18:37 am »
likley a cold solder joint or bad cap on the chassis causing a vertical/horizontal deflection problem.( I couldn't tell which way it was smushing from your description)
You likley need to open it open and operate on it to fix it--don't do this if you didn't know that there are 24,000V of juice running around in there.
Scott84
« Reply #2 on: February 08, 2005, 09:34:29 pm »
yikes. 13inch tvs are only $88 at costco anyways....
