Author Topic: Wico P360's vs Happs P360's  (Read 1641 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« on: February 07, 2005, 03:45:20 pm »
I just bought a couple of used wico p360's and they are a little different that my happs versions.
They are lacking the pivot bushing..
Just wondering if the older ones have them? If not I need to order some.
Later,
dabone
NoOne=NBA=
Re: Wico P360's vs Happs P360's
« Reply #1 on: February 07, 2005, 06:26:44 pm »
Are they leafswitch/balltop Wicos with the P360 add-on module in place of the leafswitches?
If so, they use the standard rubber grommet that was on the leafswitch sticks.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #2 on: February 07, 2005, 06:31:16 pm »
Do they have the rubber grommet inside, or the spring?  I believe spring ones ought ought to have the pivot cone (you do mean the little cone shaped thing, right?), but grommet ones do not.  That said, I have some spring Wicos with the cone missing, they still work, but the feel is a little off, and I worry that too much use that way will wear the plastic in the base assembly.
dabone
  • Time to work...
« Reply #3 on: February 07, 2005, 08:06:41 pm »
It's the ones with the spring.
I grabbed a pivot ring off of one of newer p360s and it fit.
So I need 2 pivot rings for these joys.
I just emailed the seller I'm hoping he still has them laying around.
If not the sticks get shelved till the next happ order.
(I'm not gonna pay for 2 pivots plus shipping from happs on a single order)
Later,
dabone
Kremmit
  • - AHOTW -
« Reply #4 on: February 07, 2005, 10:01:13 pm »
That's good news; I had figured p360 cones would fit my Wicos, but confirmation is good to have.  Now I need to order some, too!
