Author Topic: Wire length for CP?  (Read 1088 times)
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
Wire length for CP?
« on: February 02, 2005, 04:16:50 pm »
I am working on my first cab and I wanted to place the control buttons (shutdown, pause, exit, config, etc...) on the front next to the TV. But for my design this is about 3-4 feet from the encoder. Not knowing much about voltage degredation over distances, I know that the voltage used is low I just don't know what distance I will start to see issues. I'm using an IPac4, any ideas???
The Way Back Machine - http://www.taborious.com
quadmasta
  • Last login:May 18, 2022, 03:23:00 pm
    • Approximate Arcades
Re: Wire length for CP?
« Reply #1 on: February 02, 2005, 04:17:48 pm »
Ss long as you're not using multiple reels of wire to run to the buttons, you'll be fine.
pointdablame
« Reply #2 on: February 02, 2005, 04:40:46 pm »
you will have no problem with 3 or 4 feet... you wouldn't have problems over 30 or 40 feet..... :)
first off your and idiot
Taborious
  • Win or go Home!
« Reply #3 on: February 02, 2005, 04:48:40 pm »
Thanks, I can trick things out a little now...
