Author Topic: Hey Dabone!  (Read 986 times)
Justen
  • Last login:February 14, 2007, 10:10:46 pm
Hey Dabone!
« on: January 25, 2005, 10:37:25 pm »
Dabone,
    A while ago you said we had the same 27" monitor, which a sharp image si-327 manual works for. I am trying to connect the monitor through a JPAC and using an arcade vga card, but am having alot of trouble getting the sync right, the picture will not hold vertically and scrolls real slowly despite my best efforts.
I know this prob been covered a few times but do you have an idea how to sort the sync on this particular monitor?
Much appreciated
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Hey Dabone!
« Reply #1 on: January 26, 2005, 10:03:52 am »
If I remember correctly, that chassis has a switch to go from positive/negative sync.
Found it, it's the switch closest to the rear of the board near the video connector.
Make sure those switches are set to negative.
(Towards the outside of the board.)
Later,
dabone
