Author Topic: Composite/S-video to VGA?  (Read 1551 times)
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« on: January 24, 2005, 01:41:03 am »
I'm working on plans for a bartop, but am currently lacking a screen. I was thinking about using a computer monitor that I have sitting around, but I want to be able to use normal video on it too. Since the bartop will most likely not have a computer in it I can't use a video capture card. Is there a way to easily convert composite or s-video to VGA?
As a side note:
The only other option is to use a small TV that only has HF input. Is there a way to convert composite or s-video to hf, without a VCR?
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
StephenH
Re: Composite/S-video to VGA?
« Reply #1 on: January 24, 2005, 05:48:26 pm »
There are such converters available.  Additionally, you might able to get by using a TV Tuner Card on the PC.
Tahnok
    • Table Arcades
« Reply #2 on: January 24, 2005, 09:42:20 pm »
Anything specific? I tried doing searches but only came up with units over $100 and way too complex for what I need. I don't want to use a tuner card because I am not planning on having a full PC. I suppose if that is the only way to do it cheaply, I will have to. Any ideas for tuner cards?
