Author Topic: How to mount my joysticks  (Read 2369 times)
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« on: October 16, 2002, 06:19:24 pm »
I ordered some of the happs Supers, and I've got a couple of the Happs button-tops, and I've got one of the ball-topped sticks from Ultimarc.
I'd like to go for that really cool "plateless" look that so many folks have on their CP's and cabs.  With just the plastic shield above the control panel, oh and obviously the stick too.
Can someone provide a good site on how to go about doing that?
".....its like a Koala crapped a rainbow in my brain!"
Octagon3k
  • Last login:October 16, 2002, 10:57:33 pm
Re:How to mount my joysticks
« Reply #1 on: October 16, 2002, 10:59:41 pm »
You can just screw them in from the bottom with wood screws, but some people have said they had trouble with the joystick breaking through (I haven't had that trouble with particle board 5/8 in though)..........Or you can get some flat machine screws, or the like, and countersink them in........then cover that with wood putty.
Smack
  • Last login:May 07, 2013, 11:40:41 pm
  • Who changed my avatar?
« Reply #2 on: October 16, 2002, 11:51:56 pm »
Nothing to add really, but your topic title cracked me up... ;D
Smack
Never Let Donkey Kong Use Your Toilet.
(We're talkin' big processed brown bananas...)
Somebody out there stole my sig! LOL
dac
  • Last login:May 27, 2005, 10:13:46 am
  • newb
« Reply #3 on: October 17, 2002, 01:29:25 am »
the forums are a good place to search here... Happs also sells some black screws / nuts tht you can use that work great... just don't have the part number off hand...
It really depends on a couple of factors... material type (ply or particle?  thickness?) abuse (trying to beat Zankuro in samurai showdown4... how do you beat that freak!!!) and asthetics... do you mind 4 boltheads @ the joystick?  if so screw from underneath...
The bolts from happs worked best for me... their heads (sorry bad thought about the title ;) are smooth, so you don't loose skin and they fit perfectly....
hope this helps...
"my first .002 are free!"
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #4 on: October 17, 2002, 08:17:31 am »
I couldn't find the site I bookmarked that showed how NOT to mount them, which I found helpful...
I used the joystick plate/base to mark where I needed to drill (center hole, 4 screw holes)
I then drilled a hole for the joystick shaft (1 1/8" i what I used) Basically most people use four 3/16" carriage bolts (aces hardware has em)
from the top of the CP wood/lexan/etc  then through the supers base (which is underneath your control panel).   Put some nuts on there and then assemble the shaft with the plastic circle on top.
If I find the how NOT to do it link I'll edit this post...
rampy
HeadRusch
« Reply #5 on: October 17, 2002, 09:40:37 am »
You guys have sick minds.  The title wasn't "how to mount my joysticks without Vaseline" or anything.. :D
Ok, thanks for the tips...3/16" Carriage Bolts added to HomeDepot list.
Is 1 1/8" enough for the joysticks to travel all the way?
Thats the same size to use for the buttons, right?
I'll practice on some cardboard boxes first.
I do like the idea of countersinking flat-head screws and covering them with putty however...that ought to look quite professional.
I think I'm going to build a cardboard prototype this weekend, so I'll have something to play with, so I can take my time and not rush the cabs :D
Tonite I gotta build up the new PC and make sure its working ok, do some benchmarks, and go from there.
Frightening Fact of the day: 512 megs of PC133 ram for $24.00
On my first 486, going from 4 megs to 8 megs of ram cost me an
additional Thousand Dollars I think.
:P
Well...cost my parents...but thats what Doom really required so.... :D
hyiu
    • www
« Reply #6 on: October 17, 2002, 10:12:28 am »
I might have read your last msg wrong...
push buttons doesn't need screws... they come with a nut and mount themselves in....
as for if you want a clean looking cp, are you using lexan on top ?? if so, route a bit on the wood for the joystick screws, then mount the joystick screws below the lexan, so, when the lexan is placed on top, you'll see no screw heads other than the corner ones which is used to secure the lexan... very professional looking... (and you can sandwich an artwork in btw !!!...)
hope it helps....
Chris
    • Chris's MAME Cabinet
« Reply #7 on: October 17, 2002, 10:12:52 am »
I didn't bother with putty... I just used a larger drill bit to enlarge the top of the bolt hole (since I don't have a proper countersink bit) to get the bold heads under the surface of the panel; the artwork between the panel and the plexi hid the holes just fine.
The only downside is that if you need to remove the bolts for whatever reason, you have to completely disassemble the CP to get the plexi and artwork off.
--Chris
--Chris
rampy
  • *shrug*
« Reply #8 on: October 17, 2002, 11:03:27 am »
FYI  home depot doeisn't have 3/16" carriage bolts they only have 1/4" (you can use the 1/4" ones but they are tight - need to widen the holes on the super's base...)
Ace hardware has em though... (the 3/16")
rampy
isugoat
  • Last login:March 15, 2004, 10:46:51 pm
« Reply #9 on: October 17, 2002, 12:41:01 pm »
Check out http://home.earthlink.net/~seanhat/arcade/, LuSiD's site.  Go to download section and download the control panel template.  The measurements are perfect for Happs Super.
As far as what size bolts to use, I forget which size I used but I just brought my joystick to an ACE hardware and dug through the bolts until I found some that fit snug.
