Author Topic: Can the AVGA res tool be used with Mame 0.55?  (Read 1481 times)
jimj
  • Last login:August 27, 2024, 06:39:31 pm
« on: January 20, 2005, 11:15:17 pm »
It doesn't look like Mame 0.55 supports game specific ini files.  If this is correct, is there any way to use the AVGA res tool with Mame 0.55?
TIA,
Jim
Re: Can the AVGA res tool be used with Mame 0.55?
« Reply #1 on: January 21, 2005, 05:41:50 am »
I'm sure game-specific ini's have been possible since before .55, what makes you think they aren't?
Spartan
  • Last login:December 02, 2009, 07:09:38 pm
  • I like stuff!
    • The Municade
« Reply #2 on: January 21, 2005, 01:46:04 pm »
Weren't they .cfg files back then?   ???
jimj
« Reply #3 on: January 21, 2005, 01:50:40 pm »
There's no ini directory underneath the mame directory.  There's no option in the mame.ini file to specify an ini directory.  When I tried dropping my 0.88 ini directory under my Mame 0.55 directory it wasn't used.
« Reply #4 on: January 21, 2005, 02:01:02 pm »
You might be right.  I was using MAME back then but to be honest I don't ever remember the ini folder not being there...maybe I just didn't use it back then as I do now.
Just checking, are you sure you don't have the DOS version?
jimj
« Reply #5 on: January 21, 2005, 08:30:22 pm »
I doubled checked, I am using the Windows version.
