Author Topic: Path not Found Error - Lazarus  (Read 1854 times)
Jungle
  • Last login:March 05, 2006, 08:38:19 pm
« on: October 16, 2002, 01:02:22 pm »
I've been trying to set up Lazarus and I've gotten as far as parsing the Mame dat file, but when it goes to check for the ROMS it stops at the "Checking Vdir: 0" screen and then I get a "Runtime Error 76 - Path Not Found".
Howard has been coming up with some suggestions in another thread (which I appreciate), but I am wondering if anyone else has had this problem, and if so, what they did to solve it.
I have checked and rechecked my dirs.ini file to verify that the ROM paths listed exists and contains the roms.  Howard did confirm that this error is related to the ROMs path.
FWIW, I am running Win98.
Thanks for any suggestions.
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Re:Path not Found Error - Lazarus
« Reply #1 on: October 16, 2002, 02:04:17 pm »
I couldnt get it going either.  But I have to run Arcadeos since I have an arcade monitor.  Hopefully I can figure it out in time for Andy's arcade video card.
turboc
  • Last login:October 30, 2004, 08:27:55 am
« Reply #2 on: October 16, 2002, 05:58:35 pm »
I'm having the exact same problem.  I've checked all my paths multiple times and still can't get it to work.  ???
Jungle
« Reply #3 on: October 17, 2002, 08:52:11 am »
What OS were you guys using?  Maybe there is a common problem?
I'm using Win98 (the first edition) on both computers that had this problem.
  • Last login:Today at 02:27:12 am
« Reply #4 on: October 17, 2002, 01:54:39 pm »
Well that might be part of your problem although I doubt it.  I only check compatability for 98se and above.  98 is missing a lot of stuff as is 95 and anything before it.  It will run on it, you just have to download a butt-load of stuff which I don't include.
turboc
« Reply #5 on: October 17, 2002, 09:27:36 pm »
I'm running Windows 2000, SP3, with MAME and Lazarus on drive D.  Tried Lazarus on drive C, but MAME still on D.
Jungle
« Reply #6 on: November 27, 2002, 08:47:35 am »
Just a quick update....
I downloaded Lazarus 4.0, and after doing some work to get it installed, it *does* recognize the VDirs on my Win 98 (first edition) machine.
So, if you could never get 3.0 to run, give 4.0 a try.
Now if I can just get my marquees to show up, but I am pretty sure that is user error  :)
