Author Topic: change Xbox IDE cable and improve load times?  (Read 11565 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: January 19, 2005, 08:05:34 am »
http://www.stegen.com/product_info.php/products_id/833?osCsid=40490df7015b684f104d36995f4fe5bd
is the IDE cable used in xbox really ATA33?
is it true that simply changing the ide cable to ATA166 will improve the game load times?
i cant believe it is that simple.
why not ATA166 cable in XBOX as standard???
  • Last login:February 09, 2026, 10:26:35 am
Re: change Xbox IDE cable and improve load times?
« Reply #1 on: January 19, 2005, 04:04:09 pm »
Looked at the webpage, if their data is true, it looks like it does indeed work.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #2 on: January 21, 2005, 03:49:20 pm »
Please let me know if you try it.  I would have gone ahead and ordered one if I'd seen it before I ordered my modchip.  But now that I have my modchip I don't want to place an order just for that unless I know that it works (Halo 2 takes an age to load).  You have to buy them all special-like, cos the master and slave connectors on the cable have to be spaced much further apart for an xbox than the ones on a standard IDE cable.
Best Kid iPad Apps
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #3 on: January 21, 2005, 04:51:18 pm »
I accidentally broke my original xbox ide cable when doing some hotswapping, and replaced it with a generic IDE ribbon cable from Fry's...I just plugged it in in-reverse master slave order (since it was connector spacing worked that way), and it works fine.  Its shouldn't make a difference which end connector is master, just that the middle one and other one left is slave.
shmokes
    • Jake Moses
« Reply #4 on: January 21, 2005, 05:02:06 pm »
So, did you replace it with an 80 wire cable....and if so, did you notice an improvement in load times?
Best Kid iPad Apps
Paul Olson
    • Paul's Arcade
« Reply #5 on: January 21, 2005, 05:04:34 pm »
I also used a generic ribbon cable, it works fine.  I don't know if it is faster than with the stock cable.  I broke the cheap stock one when I was swapping drives.  ::)
Dave_K.
    • Arcade Fever
« Reply #6 on: January 21, 2005, 06:32:45 pm »
LOL same as me...I ripped the pin header right out of the ribbon cable.  Was a pain to get it out of the drive afterwards.
I thought it was 40 wire not 80...whatever standard IDE cable is.  Make sure you get one with the guide (don't want to plug one end in upside down).  Anyway, it was cheap, so I don't know if it was any better than original...I didn't notice any difference in loading times (but never really looked out for it either).
shmokes
    • Jake Moses
« Reply #7 on: January 22, 2005, 02:28:15 am »
Well..there are kind of two standards.  If you look inside your computer you'll most likely see that the IDE cable running from your optical drives to the motherboard has much thicker wires (40 of them, to be exact) while the IDE cable running from the Hard Drives to the motherbaord has 80 thinner wires.
Best Kid iPad Apps
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #8 on: January 22, 2005, 01:50:36 pm »
you would think a company like microsoft would know that a 1$ cable might make a difference in speed. now granted they are pretty dumb sometimes, i think if a speed increase was possibly it would already be 80wire cable or it just doesnt matter
"Owens is the ringleader in the ass hat circus"  D K
SirPeale
  • Green Mountain Man
« Reply #9 on: January 22, 2005, 11:21:27 pm »
The hardware has to be set up to actually take advantage of the 80 wire cable.  If it's not, then it won't make a lick of difference either way.
kujina
  • Last login:November 04, 2021, 12:07:40 pm
« Reply #10 on: February 14, 2005, 10:18:53 pm »
The 80 wire cable's forty extra wires dont really do anything apart from reducing cross talk, and so they work on any ide device. But on newer hard drives the 80 wire cables are required for them to work optimally.
Vicious
« Reply #11 on: February 14, 2005, 11:44:11 pm »
I received mine today (order here if you live in the US/Canada) and haven't really bothered to time it in Halo 2 or Links 2004 but the gain claimed by most is usually only 2 or 3 seconds.  So if you're getting it to cut down on time significantly, I wouldn't recommend buying it then.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #12 on: February 15, 2005, 08:47:40 pm »
SkateDetroit
  • Last login:April 30, 2013, 01:56:36 pm
    • SkateDetroit!
« Reply #13 on: February 15, 2005, 09:56:08 pm »
I'm sure Bill didn't intend for games to be loaded off of the hard drive. Game saves are so small you'd NEVER be able to notice the difference in a virgin xbox.
As far as load times go with a new cable, negligible. You may notice some difference while FTP'ing to your box, but don't worry you're not missing out on much.
SOAPboy
  • ..::GeeK::..
« Reply #14 on: February 16, 2005, 10:44:01 pm »
not missing out on anything for ftp..
stock cable, i max out my xboxs connection..
