Author Topic: Arcade VGA card and Video Amplifier. Do I need both?  (Read 3766 times)
Wyluli
  • Last login:February 11, 2013, 06:38:03 pm
  • Stupid Stupid Rat Creatures!
« on: January 18, 2005, 08:56:58 pm »
My mame cab has a 25" ARCADE monitor in it.  Here is the info I pulled off the tag on the back of the monitor:
RCA
Tube Type: A63ADT10x05
S/N: D-NFJ81289
I need to order the arcade VGA card from ultimarc to get this monitor hooked up to my mame pc.  I'm wondering if I will need the amplifier or not?  Anyone know?
I e-mailed Andy, but the info I gave him for the monitor is either incorrect or he doesn't know for sure.
Also, if I hook up the arcade VGA card without the amplifier, will I damage anything?
Wyluli
Re: Arcade VGA card and Video Amplifier. Do I need both?
« Reply #1 on: January 22, 2005, 10:13:17 pm »
Well, I ordered the Arcade VGA card from Ultimarc today!  No one seems to have info on this mystery arcade monitor of mine.  Wish I had a camera so I could post pics.
Anyway, if it turns out my monitor does need the video amplifier and I hook it up without one, I will not damage anything will I?  What will happen?  E.g. nothing, flickering monitor, ??
SirPeale
  • Green Mountain Man
« Reply #2 on: January 23, 2005, 12:01:31 am »
That's becaue you posted the tube type, not the monitor model.
Will
  • Last login:April 08, 2012, 03:32:27 am
  • Finished Lurking.....
« Reply #3 on: January 23, 2005, 01:56:33 pm »
Look for stickers on the side of the frame of your monitor.Yours is probably a wg 25k71### and if it this monitor you do not need a video amp.If you cant find model # post a pic.
Wyluli
« Reply #4 on: January 24, 2005, 03:44:13 pm »
I don't think I'm seeing what you are looking for.  The only other info I could find was a circuit board that is brand Hantarex and a barcode with the following under it: D-5LNFJ81289
Can't post  a pic as I do not have a digital camera.
So, my main concern is just if I get the card and hook it up, I'm not going to damage the card or monitor (if it turns out it does need the amp)?
Rocky
« Reply #5 on: January 28, 2005, 10:30:56 am »
You won't damage your monitor. You'll just have a very weak signal.
Good luck,
Rocky
mnm1200
  • Last login:March 10, 2006, 05:55:34 pm
  • IANAL: I am not a llama!
Demon Dog? Urusai! ...Baka
Wyluli
« Reply #7 on: January 28, 2005, 08:17:35 pm »
« Last Edit: January 28, 2005, 08:28:00 pm by Wyluli »
Will
« Reply #8 on: January 29, 2005, 04:34:07 pm »
Not sure about your monitor but with mine i had to wrap the v-sync and h-sync into one wire and attach it to the sync on you pre hacked cable.Like this....
cable are marked as follows:
R, G, B = colours
H = horizontal sync. H and V sync can normally be connected together for most monitors to produce composite sync.
V = vertical sync
- = ground
