Author Topic: Cheap trackball Hack -- is it possible?  (Read 1025 times)
aristotle
  • Last login:January 17, 2005, 06:42:40 pm
« on: January 17, 2005, 12:18:02 am »
I was thinking about how I might save some money on arcade parts.  In a previous idea I had, I used a cheap laptop optical mouse (you know, those really small ones) under an old record player's turn table to use as a controller in beatmania.  So, in trying to figure out the cheapest way to get my trackball to work in my cab, I thought that the previous solution would hold true for this one.  Basically, attach the little mouse so it is right under the ball with only a small space about the thickness of a penny between them.  Hopefully, this should work...  Just wondering if anyone else has tried this before and if so could share their experiences with it.  Thx :D
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re: Cheap trackball Hack -- is it possible?
« Reply #1 on: January 17, 2005, 12:32:17 am »
The only way that would work is if the trackball had a odd texture or colored dots all over it. An optical mouse works by picking up changes, so a smooth solid colored ball won't work.
oldsage
  • Last login:December 19, 2005, 09:11:47 pm
  • Does SHMIGRUB ring any bells??
« Reply #2 on: January 17, 2005, 03:36:52 am »
Maybe you should litter the trackball (just a little dirt... :), i just slid my optical mouse across a clean surface on my keyboard, and it didn't work, but then i slid it along the bottom (just a little dirt, not a lot...), and it worked perfectly... Also, you'll need to flip the X axis, 'cause otherwise one you move your ball right, the computer thinks your cursor moves left...
BTW, i forgot to mention both surfaces had a solid color, and they were both relatively straight...
« Last Edit: January 17, 2005, 03:39:27 am by oldsage »
I had a cool sig once... But it had to go because of *someone*... You know who you are!
